Old 10-01-2013, 07:56 PM   #1
Mick65
Break light issues
Hello all,
I cannot figure out why my left break light isnt working. I had a tow harness on the truck and cut it out leaving a brown wire hanging loose. I didn't think it was needed but it looks like it may be. Where should the brown wire coming from the left break light go?
Thank you everybody.
Mick65 is offline   Reply With Quote
Old 10-01-2013, 08:00 PM   #2
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Break light issues
Ground ground ground... Check all your grounds back there..
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-01-2013, 08:07 PM   #3
Mick65
The brown is the ground? What should i hook it up to?
Old 10-01-2013, 08:22 PM   #4
donthekawguy
donthekawguy's Avatar
Brake not break. Sorry a pet peeve of mine.
66 shorty
donthekawguy is offline   Reply With Quote
Old 10-01-2013, 08:29 PM   #5
Mick65
Moving on... Constructive replies would be great
Old 10-01-2013, 08:57 PM   #6
TxRat
TxRat's Avatar
http://ww2.justanswer.com/uploads/se...4_PC001524.pdf
This should help...
TxRat is offline   Reply With Quote
Old 10-01-2013, 09:19 PM   #7
Mick65
Thanks TxRat. I have a similar diagram. My truck is a 65 and does not have the license plate light. Thats whats throwing me off..
Old 10-01-2013, 09:25 PM   #8
jtrichard
DITTO on the brake thingforever
jtrichard is offline   Reply With Quote
Old 10-02-2013, 12:53 AM   #9
Mick65
Wow. Didn't know I could come here for grammar advice too. Thanks folks.
Old 10-02-2013, 12:15 PM   #10
earl84
Mick65, I am only going from memory here, since I am not at home right now, and I am not an electrical guru by any means. I am installing an American Autowire harness, and if I recall correctly the brown wire provides power to the taillights and license plate when the headlight switch is turned on. I am pretty sure on the AAW harness that the brown wire went from the left rear taillight into a double wire terminal, then to the right rear taillight to a double wire terminal, then to the license plate light.
So, the brown wire is not a ground wire, but a power wire. I think the grounding happens when the brake pedal is applied and provided by the brake switch. Lots of people will add a ground from the taillight housing to the frame. This is not a part of the normal wiring harness, it is an addition they make to provide better grounding in the rear because lots of issues back there can be attributed to poor grounds.
Hope this helps somewhat. Incidentally, I could probably out-spell most people on this forum, but don't feel the need to correct anyone unless it's part of a business they operate, which literally makes me not want to do business with them if that is their level of attention to detail. That's my pet peeve.
earl84 is offline   Reply With Quote
Old 10-02-2013, 12:40 PM   #11
earl84
Now that I think about it, the grounding occurs from the taillight housing to the body of the truck. See, I told you I wasn't an electrical guru, but I am a spelling guru, haha. Woogeroo, are you trying to stir the pot? lol
Old 10-02-2013, 12:49 PM   #12
jtrichard
Earl the brake light switch does not ground it provides power thru the turn signal switch then to each brake light left and right ....as far as i know there are no ground wires in the original rear wiring harness...yes it is good to run a ground from each tail light housing to the frame to insure a good ground...and the grammar/spelling comment was meant to be tongue in cheek if it was not for spell check mine would be terrible and sometimes it still is lol ....... edit EARL we were both typing at the same time
Old 10-02-2013, 01:24 PM   #13
earl84
jtrichard, I know your comment was tongue in cheek, that's why you had a smiley face, I just am in a mood and want everyone to get along. No point in posting a comment for the sole purpose of calling someone out on something as silly as spelling like the original spelling commenter did. There's plenty of crap in life we all have to deal with that actually matters. Enough about the spelling already, whew.
I just hope Mick65 gets his issue fixed.
Old 10-02-2013, 07:38 PM   #14
gofastnut
gofastnut's Avatar
Hey Mick65,
Howz it goeng?
Have you got it fegurd out yet?
Jeff
96 C3500 Crew Cab Long bed (Waiting on Cool Name)
64 C-10 shortie stepside, "Ole Brownie"
C-10 Club
My achingly slow build: http://67-72chevytrucks.com/vboard/s...d.php?t=508345
gofastnut is offline   Reply With Quote
Old 10-02-2013, 08:01 PM   #15
Irishbleueyes
Where would we be without our **** stirrers...
Irishbleueyes is offline   Reply With Quote
Old 10-07-2013, 06:23 PM   #16
Keating121
Keating121's Avatar
Ben workin on me lite issues two!! Hahaha Couldn't resist.
I really have been working light issues for the past 2 days, I found a spare brown wire too. I've been researching diagrams and the license plate is brown as are the tail lights, but my "extra Brown wire" was, I believe, an extra left over from when it had the side running lights on the back and front fenders.
Didn't help my problems, but knowledge is Power!! Good Luck!!
8/24/13 First Classic Truck
'67 Short Fleetside, Candy Apple Red! 350ci, Holly 750 double pumper (too much, will change soon), Headers with FlowMaster exhaust, 700R4 tranny.
Keating121 is offline   Reply With Quote
Thread Tools
Display Modes
