Old 10-02-2013, 05:38 PM   #1
cortcomp
cortcomp's Avatar
Washer Pump doesn't fit?
I took the wiper motor/washer pump out of my 66 to replace the seal between the motor in cab, wiper motor mounts, etc. While it's out, i want to replace the wiper motor. I got the little repair kit and it didn't have the right pieces (or the 66 doesn't have the pieces that later models i've worked on have.) None of the kits seem to have the bellows.
No problem i thought, the washer pumps are under $30 so i'll get one in and just switch the whole assembly. I know many don't like the mechanical pump, but i have several cars with them and they work well and i think the squirters are nostalgic.
Anyways, i got a new anco 61-72 which shows like 62-73 pickups. Every site i've found shows that those years (in a couple brands) use the same wiper motor. It came with a new plastic globe gear, but my motor has a metal one on it.
The new washer pump has a lever with an arm to trigger it, the old one had a square block that just moved in and out. No big deal, should still work, but then i went to mount it and the new pump mounts are wider than the old, one bolt is hanging off the end of the wiper motor mount plate!
All the research i've done today pretty much tells me that every vendor is going to send me a washer pump for a 64-72 as the same. So either this motor isn't for a 64-72 (which is crazy because it mounts up, wires up, and works fine, and i wouldn't think that'd be the case) or the earlier C10s don't have the same mounting width on the washer pumps and they DON'T fit the same washer pumps as later C10s.
Anyone have experience with this? It doesn't even seem to engage the global gear at the right place.
http://www.summitracing.com/parts/anc-61-02
Project "i'm just going to clean up the interior and the engine bay":
http://67-72chevytrucks.com/vboard/s...d.php?t=550931
cortcomp is offline   Reply With Quote
Old 10-02-2013, 05:45 PM   #2
cortcomp
cortcomp's Avatar
Re: Washer Pump doesn't fit?
Here are some pics to show the difference...maybe someone will recognize the pump as a different year or something?!
Old 10-02-2013, 08:39 PM   #3
1963c-10
1963c-10's Avatar
Heres the one I have from a 63 going into my 63 if it helps any. I can pop the cover off and see which action it has inside.
I do need to know what the white and pink wires run to if you can lend any help on that while your under the dash.
Im converting from single speed to two speed w/washer. There are two different two speeds...one w/4 prong plus (as ours) and a 3 prong plug....at least in 1963.
Mine is the same inside as yours and also has the metal gear.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-02-2013, 08:50 PM   #4
cortcomp
cortcomp's Avatar
Thanks for the pic! I have the factory harness so i can get the wiring back to normal. I wonder if i have an earlier motor/pump? All the after market stuff says 64-72, so i wonder if someone swapped an earlier setup in. If possible, can you measure the distance between the two washer pump mounting screw holes so i can compare? Then i can report back what i've found.
Old 10-02-2013, 10:16 PM   #5
1963c-10
1963c-10's Avatar
yeah i can get them....give me a few
Old 10-02-2013, 10:32 PM   #6
1963c-10
1963c-10's Avatar
looks like 3 13/16" center to center measureing across the back
Old 10-03-2013, 11:03 AM   #7
cortcomp
cortcomp's Avatar
Thank you for the measurements, i will measure both pump mountings when i get home today and post what i find.
Old 10-03-2013, 11:07 AM   #8
1963c-10
1963c-10's Avatar
Cool. I have a 63 3 post 2 speed wiper w/washer also. Ill look at that washer pump tonight too.
Old 10-03-2013, 05:32 PM   #9
cortcomp
cortcomp's Avatar
measuring the distance between the two mounting holes on the back of the washer pump (as show in the pic) i came up with this:
old - 3 15/16
new - 4 5/8
Old 10-03-2013, 07:26 PM   #10
1963c-10
1963c-10's Avatar
I could go a 1/16" either way on my measurement, but your right...about an inch off.
Old 10-03-2013, 07:34 PM   #11
cortcomp
cortcomp's Avatar
I see 69ish camaro's have the same wiper motor and washer pump as our trucks? If so, if you really can just cram just about anything in there, who knows what this came from if not original?
Old 10-03-2013, 09:55 PM   #12
1963c-10
1963c-10's Avatar
ill see if i can find the oem part #. i see alot of the nos units pretty affordable online all the time
Old 10-04-2013, 09:57 AM   #13
cortcomp
cortcomp's Avatar
Well what i'm afraid of is that the new washer pump i have IS for a 66, and that i have the wrong wiper motor. No numbers on it anywhere. Not knowing what it is from, i may have to buy a wiper motor for a 66 to match my new pump, even though this wiper motor worked fine!
Old 10-04-2013, 10:06 AM   #14
1963c-10
1963c-10's Avatar
Can you return the pump? Maybe the link below...get the guy to measure it for you.
Should be the same from 64 to at least 77.
Check out this link, this is an American made part too
http://www.ebay.com/itm/New-Washer-P...1f7031&vxp=mtr
Old 10-04-2013, 10:07 AM   #15
cortcomp
cortcomp's Avatar
Yes i can, but then i have my old, dusty, dried out pump and no idea what i should be looking for to replace it.
Old 10-04-2013, 10:12 AM   #16
1963c-10
1963c-10's Avatar
Get the same size mounting locations that I gave you and you should be fine. Measure the wiper motor for your proper mounting size. All the washer motors are 2 prong, so no issues there. Just needs to mount to the wiper motor properly.
As long as your replacement is the 3 13/16 - 3 15/16 mount, you should be fine.
Old 10-04-2013, 10:56 AM   #17
cortcomp
cortcomp's Avatar
The trouble is finding a place that has some in stock to get out and measure, and i don't see most places listing mounting data I'll figure something out over the weekend!
Old 10-04-2013, 10:58 AM   #18
1963c-10
1963c-10's Avatar
Send the guy on ebay a request for the measurement. May help narrow down the years.
Old 10-05-2013, 01:06 AM   #19
Captainfab
60-66 Nut
I've got a '64-'66 wiper motor with the washer pump at the shop. I'll try and remember to measure it tomorrow.
Old 10-05-2013, 09:44 AM   #20
cortcomp
cortcomp's Avatar
I would appreciate that, thank you. sent some emails to some vendors and ebay sellers but no answers yet. Looking to see if anyone has a motor in stock that i can compare with mine. No one yet, checking summit now.
Old 10-06-2013, 12:24 AM   #21
Captainfab
60-66 Nut
The '64-'66 wiper/washer I checked at the shop today measures 3 15/16" center to center of the holes.
Old 10-06-2013, 01:11 AM   #22
cortcomp
cortcomp's Avatar
So, there it is, the washer pump vendors are selling for 66 are not for 66. almost all of them list this one as their 64-72ish model.
Old 10-06-2013, 11:10 AM   #23
bama63
bama63's Avatar
oreillys shows 63-72 trucks and panels also 74-78 jeep cherokee and wagoneer are the same http://www.oreillyauto.com/site/c/de...3292&ppt=C0047 hit the compatibility button , hope this helps.
Due to financial constraints, the light at the end of the tunnel will be shut off until further notice
bama63 is offline   Reply With Quote
Old 10-08-2013, 04:39 PM   #24
cortcomp
cortcomp's Avatar
I ordered another one from a different vendor today (had to order some more parts anyways.) so we'll see if it fits when it gets back.
I wonder if the aanco 61-02 is the correct pump, but the wrong pump is in the box or someone returned the wrong one or something and i got it. We'll see closer to the weekend and i'll update here what i find. Thanks everyone for the research and measurements!
Old 10-08-2013, 04:49 PM   #25
1963c-10
1963c-10's Avatar
No problem.....it'd be nice to have a part number for future reference.
Thread Tools
Display Modes
