Old 10-09-2013, 11:32 AM   #1
bigmac73
bigmac73's Avatar
pinion yoke removal/crush washer debate
okay guys, after reading another thread the other day, we all have different opinions on removing the pinion yoke and how it will affect the crush washer.
the reason I am starting this thread, is I want to upgrade my pinion yoke to a 1350 series joint along with the rest of my drive shaft, so i need to know if this is going to grow into a bigger project than I had planned
Lets get it on....
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-09-2013, 01:52 PM   #2
70STOVEBOLT
70STOVEBOLT's Avatar
Re: pinion yoke removal/crush washer debate
The crush sleeve sets the preload on the pinion bearings. You SHOULD replace it each time you remove the yoke, but I know a lot of people don't. If it is easily accessible, I would say replace it, they are not expensive. Also, the nut should be replaced, as it is a locking nut and is designed for one-time use. If you reuse the nut, I strongly suggest using blue thread locker on it.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is online now   Reply With Quote
Old 10-09-2013, 02:03 PM   #3
geezer#99
geezer#99's Avatar
Well said Stovebolt!!
If you're gonna do it, do it right!!
I've seen people who think they can just bolt it back togethor only to get a big buck suprise a couple months down the road.
A new sleeve and nut is chump change compared to a 1000 bucks for a new rearend.
geezer#99 is online now   Reply With Quote
Old 10-09-2013, 02:19 PM   #4
bigmac73
bigmac73's Avatar
if i torque the new nut back to specs then the preload should be the same, as the crush has already been established??
Mike
Old 10-09-2013, 02:56 PM   #5
Lees68GMC
Lees68GMC's Avatar
LOOK just for frame of reference here, the Gear Motive master kits from Summit for our trucks with everything you need including new bearings, shims, bolts, marking compound & brush, gasket, crush sleeve, seal and nut runs $75.00.
Risk major differential damage just to try and save $75.00? You get what you deserve.
68 GMC SWB Vortec 5.3
98 Chevy Blazer ZR2
94 Mazda Miata, LS2 6 speed, sold
"No matter what happens, nobody gets out alive"
Lees68GMC is offline   Reply With Quote
Old 10-09-2013, 05:10 PM   #6
70STOVEBOLT
Theoretically, yes.
200,000 Mile Club
Disc Brake Club
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
Old 10-09-2013, 05:31 PM   #7
marvgarr68
marvgarr68's Avatar
I have done it lots of times and have never had a rear end go out. What you do is get a center punch mark the yoke/nut/pinion shaft in line remove change seal and reinstall yoke inline with mark. Tighten nut to the mark and you are done. If you want to change yoke get an inch pound torque wrench turn yoke nut measure torque to turn pinion shaft all the way around. Replace yoke and seal install nut tighten check turn torque on pinion tighten tell the torque isthe same. It's all in the service manual also. It was good enough for GM so I see no problem.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 10-09-2013, 05:41 PM   #8
Dunenutt
Newbee
Dunenutt's Avatar
I have done it many times to replace pinion seals. Just don't hit it with an impact wrench, or crank it down. It takes a lot of torque to crush that sleeve, so it should not move. I agree with locktighting the nut. Re-setting the preload on a differential with a lot of miles is not a good idea.
Dunenutt is offline   Reply With Quote
Old 10-09-2013, 05:58 PM   #9
Bigdav160
Bigdav160's Avatar
Do you think Chevrolet would know the answer? Do you think their engineers are smarter than most on this forum?
Look it up in the service manual. There is the answer.
BTW, removing and reinstalling the yoke will not change the preload if done properly.
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Thread Tools
Display Modes
