Old 10-15-2013, 07:24 PM   #1
In The Ten Ring
Will a 1968 stepside fender work with a 1972?
It looks like I may have found a nice stepside rear fender WITH the driver's side spare tire cutout for my truck.
BUT I need to be sure before I bite and pay a boat load for shipping.
Will a 1968 rear stepside fender work on a 1972?
Is the side marker light cutout the same?
Thanks!
In The Ten Ring is offline   Reply With Quote
Old 10-15-2013, 08:57 PM   #2
Tim Christian
Tim Christian's Avatar
Re: Will a 1968 stepside fender work with a 1972?
Yes it should but I know they made one for a long bed and a short bed on 55 to 66 models with the spare tire cut out not 100% sure on 68 to 72 with a cut out?
Tim Christian is offline   Reply With Quote
Old 10-15-2013, 09:01 PM   #3
cwilkie
Chance
cwilkie's Avatar
I am pretty sure it it will work. The step fenders on my 1968 are from a 1972.
1968 Chevrolet Stepside
BB 396 w/TH400
1972 Chevrolet 3/4 Ton 4x4
BB 496 w/TH400
cwilkie is offline   Reply With Quote
Old 10-15-2013, 09:08 PM   #4
Tim Christian
I know it will bolt on just fine but is the spare tire cut out the same on long bed as short bed?
Old 10-15-2013, 09:25 PM   #5
In The Ten Ring
I've heard the size is the same for both long and short wheel bases, mine is a short wheel base.
I'm mainly worried about the side marker cut out. Will my light work on that fender?
Old 10-15-2013, 09:28 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
The sidemarkers are all the same.Even on Burbs and panels.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-15-2013, 11:31 PM   #7
In The Ten Ring
Thanks guys.
So the side marker on a 68 fender will allow me to attach a side blinker without issue, correct?
Now, as to the spare tire cut out (which is essential that it works for me), does anyone know if there are differences betten lwb and swb?
*Mine is a swb.
Old 11-08-2013, 08:52 PM   #8
Catslug1
Yes. The position of the cut out is different between swb and lwb. Is the fender your are looking at lwb or swb?
Catslug1 is offline   Reply With Quote
Old 11-08-2013, 08:54 PM   #9
In The Ten Ring
No idea! I'll have to call the guy and ask. Thanks for the update! I'd hate to get stuck with a fender I can't use and not be able to quickly sell.
Old 11-09-2013, 08:19 AM   #10
Catslug1
Let me know. If lwb, I would be interested in purchasing with tire mount hardware. Thanks.
Old 11-09-2013, 11:24 AM   #11
WIDESIDE72
WIDESIDE72's Avatar
68-72 not cut out stepside fenders interchange. 67 will as well but no marker hole. Ive jad 4 or 5 stepsides and 8-10 pairs of fenders some with and some without cutouts but i have never had had any with a cut out that i knew for sure came off a lwb so cant say as far as swb and lwb cut out being in a different place/ shape. A 68 fender will not have a hole for the wiring asthe markers were no lit, reflectors only. You just need to drill a hole in the backside. I believe factory is 1/2".
WIDESIDE72 is offline   Reply With Quote
Old 11-09-2013, 12:19 PM   #12
68shortstep
Looks good at 20-ft .....
68shortstep's Avatar
LWB fenders with the cutout are definitely completely different at the cutout from those for the short wheelbase, as are the brackets which holds the spare tire, but I think there'll be no problem on year-built. Just be SURE you're getting the right body-length fender, AND the right bracket for the spare mount.
Notice in the attached photos that the cutout on the LWB fender (orange truck) goes down farther, thru the body line, while the SWB cutout is well-above the contour line (green fender). Also, the hole is a dead giveaway for a SWB fender. No hole for a LWB.
Sorry if either of these are a member's truck. I just grabbed & saved the pix for my file, when I saw them.
Dave
68shortstep is offline   Reply With Quote
Old 11-09-2013, 05:42 PM   #13
In The Ten Ring
68shortstep
THAT CLEARS UP EVERYTHING! If a swb has a hole like on this green truck, then it should be very easy to see if this fellow's fender will fit my truck.
I'll call him tonight (I think I have his number still).
Now on the side marker light, all I need to do is drill an extra hole and I can install my light assembly (with wires)?
Old 11-09-2013, 08:08 PM   #14
HIGHWAY BY THE SEA
HIGHWAY BY THE SEA's Avatar
I just installed light sockets in my 68 that never had any. There was no need to drill any holes that I saw, so I did not. Sure wish I could find a Longbed fender with the spare cutout like you did! Good find!
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside
GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed
http://67-72chevytrucks.com/vboard/s...d.php?t=584617
PROJECT JIGSAW 1967 GMC C3500
GREAT WHITE 1986 Blazer M1009 454 engine w/700R4 transmission gas conversion
HIGHWAY BY THE SEA is offline   Reply With Quote
Old 11-09-2013, 09:17 PM   #15
WIDESIDE72
WIDESIDE72's Avatar
I just pulled the stpside fenders off a 68 lwb stepside. It only had reflectors, no he in the bucket inside the fenderwell. I wonder if some had the hole and others didnt.
Old 11-10-2013, 12:33 AM   #16
In The Ten Ring
I just talked to the owner (of the fender). I need to figure out a business to ship it to but that might be easy.
I'm going to look at my current fender to see if it has the hole in it. I want to be 100% free of surprises!
My fender is fine, just that it is LOADED with bondo.
Old 11-10-2013, 08:45 AM   #17
Reflectors were standard in 68 & 69. Side marker lights were optional. 1970 is when they side marker lights became standard equipment.
Old 11-10-2013, 04:13 PM   #18
68shortstep
I've not seen dozens of these things, but I've never yet seen a (stock) LWB fender that had the hole.
The reason is the bracket that the spare tire mounts on: on the SWB, there's a single strut that passes thru the hole (with a grommet in the hole from the factory) & bolts on a vertical angle iron, hidden INSIDE behind the fender. Look at the LWB orange truck photo, and you can see that BOTH of the vertical angle irons bolted to the bed, that the tire mounting bracket itself bolts to, are OUTSIDE the fender.
Both vertical angle irons outside the fender = LWB bracket only.
That's why it's important to get the correct bed-length bracket too..... they are made differently. Struts different length & bolt-on attachment points.
Also on the green truck fender, if you look closely, you can see about a 1" long angle iron above the fender, below the bed-edge roll, & above the hole on the bed side ---- it's actually a folded angle iron that runs on the bottom of the bed lip, that the top leg of the SWB tire bracket bolts to on top of the bed lip, and a second leg bolts onto the short piece above the fender.
SWB Photo with tire bracket bolted on: (thanks again to whichever member I copied this pic from). You can clearly see the three right-side bracket legs; the leg on top of the bed, the one between the bed & fender & the one passing thru the hole.
Thread Tools
Display Modes
