Old 10-21-2013, 10:17 AM   #1
Branman1971
Branman1971's Avatar
Need New Flexplate. Pull Motor Out?
I need to swap my flexplate in my 350sb/TH350 combo. I am considering pulling the entire motor and tranny and going through them. Not rebuild, but clean them up real good and repaint the block, new motormounts, new valve cover gaskets, tranny pan gasket, seal up the leaks. Has anyone pulled the motor and tranny out of one of these out as One Unit? I have pulled them before out of Fords still bolted together. Where should I get the flexplate from? I know there are many ones to consider depending on hp and such.Thanks!
Active duty Navy CPO
1961 C10 SWB
1963 C10 LWB (donor)
1965 C10 LWB BBW
Branman1971 is offline   Reply With Quote
Old 10-21-2013, 06:53 PM   #2
MARTYZ
MARTYZ's Avatar
Re: Need New Flexplate. Pull Motor Out?
If I was doing all that I would just remove the front clip, only
take you about an hour tops, dozen bolts, two rad hoses and unplug some wires and everything is wide open and easy to access. Just my thoughts. Flexplate can be purchased at any auto parts supplier and can be replaced by just sliding trans back
MARTYZ is offline   Reply With Quote
Old 10-22-2013, 11:30 PM   #3
Branman1971
Now look what you made me do!
1961 C10 SWB
1965 C10 LWB BBW
Old 10-22-2013, 11:40 PM   #4
ChevyTruckGuy
ChevyTruckGuy's Avatar
lol.....Cool. I like the idea, now you can change out as many parts as possible on the motor while its out or when it does get out. Clean & maybe paint engine compartment ect.......Looks like fun.
1966 Chevy C 20 Lwb (Now a project)5.7 400hp
1996 Chevy Silverado Reg Cab Lwb (Daily Driver) 5.7
2000 Chevy S-10 Ex Cab Lowered 4/4 4.3 (For Fun)
2008 GMC Sierra Ex Cab 5.3 (once a month driver)
Wife's 74 Ranchero 500 351 Cleveland (One Owner)
My name is Mike and im in So. Cal (Hi Desert)
ChevyTruckGuy is offline   Reply With Quote
Old 10-22-2013, 11:49 PM   #5
Branman1971
1961 C10 SWB
1965 C10 LWB BBW
Old 10-23-2013, 12:56 AM   #6
donthekawguy
donthekawguy's Avatar
Pull it all! Clean paint update!
66 shorty
donthekawguy is offline   Reply With Quote
Old 10-23-2013, 09:03 AM   #7
WhippinSaw
WhippinSaw's Avatar
I prefer to pull the motor and tranny as a unit instead of just pulling the motor and propping up the tranny. Just use a bucket to catch the trans fluid that will leak out the drive shaft spline on the trans when lifting and tilting. Should be really easy with the front clip apart but not necessary. Enjoy
WhippinSaw is offline   Reply With Quote
Old 10-23-2013, 10:05 AM   #8
1963c-10
1963c-10's Avatar
Thumbs up Re: Need New Flexplate. Pull Motor Out?
I like the under hood check list.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 10-23-2013, 12:27 PM   #9
cg285
if you are just replacing the flexplate it's a 30min job and nothing gets pulled
cg285 is offline   Reply With Quote
Old 10-23-2013, 12:28 PM   #10
Branman1971
Thanks for the help guys. I guess I will be pulling this thing myself because I have no friends. Lol. As for my check list it serves me well as a reminder because I can't remember anything. I've even got a reminder in on the left-hand side of the hood to love on my wife so she doesn't feel neglected for all the attention that I'm giving to "damn truck". I think that's going to be the name of my truck as it was affectionately named by my wife.
1961 C10 SWB
1965 C10 LWB BBW
Old 10-23-2013, 02:18 PM   #11
Branman1971
Yeah, I'm sure I will be doing more than just the flexplate. So far I have planned:
Flexplate
clean up engine bay
valve cover gaskets
cap/rotor
plugs/wires
Tranny pan gasket
Tail shaft seal
Paint block
new headlight adjusters
Tranny crossmembers
re-run the wiring
So yeah, I wanna pull it out and get a good look at everything. I wish I had a sandblaster!
1961 C10 SWB
1965 C10 LWB BBW
Old 10-23-2013, 02:47 PM   #12
1963c-10
1963c-10's Avatar
If your going to pull the motor...id consider the rear main seal and an oil pan gasket too.
Old 10-23-2013, 02:49 PM   #13
Branman1971
Good Eyed Deer!
1961 C10 SWB
1965 C10 LWB BBW
Old 10-23-2013, 03:54 PM   #14
A.T. RockDriller
A.T. RockDriller's Avatar
Hey Branman...
'63c-10 is right....
While ya have it out...change every external seal on the tranny and anything else you can think of.
Bench work is always more fun than "under-the-truck" work.
BTW: I really like yer "Damn Truck"...
Les Hunter
'59 3803 someday to be 3853
'63 GMC K1000...351E, TH400 Daily
'66 GMC 4000...351C, 5&2
A.T. RockDriller is offline   Reply With Quote
Old 10-23-2013, 04:16 PM   #15
A.T. RockDriller
Just so you know what you're up against...
This is what happened to me when I decided to swap my motor mounts.
Copied from Build Thread:
Hey...Grease
Good ta see ya.....
I'm gettin my a$$ kicked on this one....
I'm just closing in on the motor mount swap....
Anyway.....
I'm down to finishing up the column.....and the attached shift linkage an...an...an..........and maybe that's it. Other'n boltin it back together..
I Gotta think 'bout that....Either way....I am ok to start it after I wire the engine harness....Oh. After I finish plumbing the aux. fuel tank (so it will be the only tank) because I yarded the one out from behind the seat....Just have to bend the rest of the tubing....I'll take a pic later.
Anyway, here's a couple for ya...
Les Hunter
Les Hunter
Old 10-23-2013, 04:19 PM   #16
A.T. RockDriller
And....while I was doing that....I was doin' this....
Les Hunter
Old 10-23-2013, 04:46 PM   #17
1963c-10
1963c-10's Avatar
Nice work Les....your truck is coming along real nice.
Old 10-23-2013, 05:33 PM   #18
Branman1971
Yeah Les, she's a beauty! I have some floorboard spots that need some help too. How did you clean up your frame? Sandblast?
1961 C10 SWB
1965 C10 LWB BBW
Old 10-23-2013, 06:37 PM   #19
par4tom
Nice looking project. But beware...
These types of projects are addicting...start with just a flexplate change and the next thing you know you've got a new engine, new paint, new upholstery, new everything!!!
Ask me how I know...sigh!
Tom
My Build Thread
http://67-72chevytrucks.com/vboard/s...d.php?t=705185
How to Get Audiophile Sound in 60-66 Trucks
http://67-72chevytrucks.com/vboard/s...=1#post7236896
Building Your Own Speaker Kick Pods
http://http://67-72chevytrucks.com/vboard/showthread.php?t=730495
par4tom is offline   Reply With Quote
Old 10-24-2013, 10:09 PM   #20
Branman1971
Ad here we go!
1961 C10 SWB
1965 C10 LWB BBW
Old 10-25-2013, 08:36 AM   #21
MARTYZ
MARTYZ's Avatar
Well that's the cheap part done now how much are you going to spend is the question or the challenge, Nice work and good looking truck !!
Old 11-10-2013, 10:46 PM   #22
Branman1971
Getting there.
1961 C10 SWB
1965 C10 LWB BBW
Old 11-11-2013, 08:22 PM   #23
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
See that was easy!!!
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 11-12-2013, 06:15 PM   #24
Branman1971
Got these done. Now to clean up the engine bay and firewall. The firewall looks like Swiss cheese with all the mystery holes drilled into it. Thank god for welders.
1961 C10 SWB
1965 C10 LWB BBW
Thread Tools
Display Modes
