Old 07-11-2003, 08:54 AM   #1
hambone1958
hambone1958's Avatar
Question Transmission help please
The project is a 1972 GMC lwb. The engine is a 1969 396 out of a chevelle. I am ready to buy a transmission but don't know jack about it. Can someone tell me does this truck have a 4" tail or 9" tail. How about a 700r4 will it bolt right in? I would like something with overdrive. Any suggestions or comments would be apperciated.
Alan
hambone1958 is offline   Reply With Quote
Old 07-11-2003, 10:34 AM   #2
cdowns
cdowns's Avatar
i think you'd be betteroff with a heavy duty rebuild of a 2004R it would bolt right in and if the truck originally had a th350 the driveshaft can be used asis
Old 07-11-2003, 10:57 AM   #3
Blue68
Blue68's Avatar
What transmission was in it? Pretty much any GM transmission will bolt right in there. You would need an adapter for a Buick, Olds, Caddy, or even a Tremec tranny, but why bother, Chevrolet has any transmission you would want. If you want overdrive, you have the 700r4, the 200r4 (either of these will do fine if they were built by a reputable shop and set up properly). If you go with a 700, you will most likely need to shorten your front driveshaft. Obviously, any automatic will require cooling lines to the radiator tank (which actually warms the fluid in the winter as well to get it up to operating range quicker). There are also overdrive manuals out there. You need to decide if you will be doing much towing as well as this should be taken into account. With an overdrive, you should downshift to 3rd for towing. The exception would probably be a manual or the 4L80, which is computer controlled heavy duty overdrive found in modern trucks. Computer control devices can be bought to make them work in non-computer equiped vehicles.
Just a few more thoughts on the matter....good luck.
http://home.comcast.net/~r.landrum/w...tos.html-.html
'68 C-10 LWB, '98 Z-71 350 w/accessories (Serpentine), Edelbrock Performer, Edelbrock 1405 (600cfm) carb, GM HEI, CompCam Extreme 4x4 roller cam, Thorley Headers, Carter Electric Fuel Pump, Vintage Air, 700r4, 3.73, disc brakes and power steering upgrades.
Blue68 is offline   Reply With Quote
Old 07-11-2003, 11:23 AM   #4
hambone1958
It came with a turbo 400 and a 350 engine. Don't plan on any towing when the project is done the truck will be my wifes weekend cruiser.
Alan
Old 07-11-2003, 12:07 PM   #5
Blue68
Blue68's Avatar
Weekend cruiser, high hp, have a th400 in hand that came in it....I'd think about putting the th400 back in. Unless the cruising is long distances I'd run what you have. No drive shaft modifications, shift linkage is set up for it, plumbing is there, you just bolt it back in.
But if your cruising highway distances very often I can understand a desire for overdrive, especially with a 3.73 rearend. If so, take a peak at www.700r4.com for casual reading if nothing else. They sell 700r4 and 4L80 transmissions.
Old 07-11-2003, 03:34 PM   #6
hambone1958
Blue 68 that web site has a wealth of info thanks
Alan
Thread Tools
Display Modes
