Old 10-22-2013, 11:07 PM   #1
rageagainstphil79
bed mount question
I have a question about the position of the bed mounts on my '66 short bed. The PO has welded the bed to the frame and I got to looking around more as to why he did that and the bed mounts at the very back of the bed are wider than the frame. It is still a trailing arm frame and measurements on my frame are the same as my '64 long bed so I don't think the frame has been swapped out. Just wondered why the mounts on my short bed are wider than the frame. Thank you in advance for any help.
rageagainstphil79 is offline   Reply With Quote
Old 10-23-2013, 01:01 AM   #2
donthekawguy
donthekawguy's Avatar
Re: bed mount question
Masybe some pics would help. The rear mount is the frame itself and the next set forward is wider. Not sure how much but the holes in the cross brace will line up. Are the braces welded to the frame? If so you could take the wood out and use a grinder to cut the welds and save the braces.
66 shorty
donthekawguy is offline   Reply With Quote
Old 10-23-2013, 07:45 AM   #3
rageagainstphil79
I will try and get some pics this evening and get them on here. I know it is a silly question I have had several of these 60-66 trucks and this is the first time I have came across this
Old 10-23-2013, 09:00 AM   #4
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
the bed and/or cross members are from a 60-62 probably. those are about 4" wider than the 63-66 frames
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-23-2013, 09:11 AM   #5
firemanjimtfd
firemanjimtfd's Avatar
Mine are the same way. May have to cut off and move inward. Is everything else the same ?
firemanjimtfd is offline   Reply With Quote
Old 10-23-2013, 10:38 PM   #6
rageagainstphil79
firemanjimfd mine is identical to that. I had the same thought as Clyde65 on it being a 60-62 but couldn't find anything to prove that thought. Ya I am just going to drill out the spot welds and move them in to where I need. The cross braces are not lined up either but I have a donor truck that I am going to get those off of. Kinda crappy that the PO welded the cross braces to the frame. Thank you guys for the help
Old 10-24-2013, 12:31 AM   #7
Captainfab
60-66 Nut
Yep, that is a '60-'62 bed. The '60-'62 frames are wider than the '63-'87 frames.
Thread Tools
Display Modes
