Old 10-23-2013, 01:28 AM   #1
natecr
Disci brake questions.
Swapping discs on the old truck, i have a ford 8.8 rear with disc brakes.. Is there a factory manual master cylinder i can use with my disc/disc setup? Thanks!
66' custom camper 327/3spd 3.5/5 drop 17"s
2013 Subaru STI stage 1, exhaust, springs, sways ect
2002 mustang Gt. Paxton novi 2000, caged, tubular everything, 441/409 hp/tq too much to list.
1994 dodge cummins, straight piped, nv4500 swapped/built too much to list.
natecr is offline   Reply With Quote
Old 10-23-2013, 11:37 PM   #2
Captainfab
60-66 Nut
Re: Disci brake questions.
I would use a manual master cylinder for a mid 70's Corvette.
Old 10-24-2013, 12:18 AM   #3
overtimeracing
overtimeracing's Avatar
I have a 68 AMC Javelin with 74 AMC Hornet Discs up front and an 8.8 from a Explorer in the rear with discs as well. We went with a dual master cylinder from an 84 F-150 and are using the little one way valves you can pick up at Summit Racing. This turned out to be an outstanding set up. I have a very solid pedal and very equal braking on all types of surfaces. I bought an adjustable proportioning valve but didn't end up using it. You can find the valves here:
http://www.summitracing.com/parts/wi...3278/overview/
Why...Why...Why...Can't I leave anything alone???
overtimeracing is offline   Reply With Quote
Old 10-24-2013, 12:44 AM   #4
NEWFISHER
NEWFISHER's Avatar
67 and up Corvette.
NEWFISHER is offline   Reply With Quote
Old 10-27-2013, 02:04 AM   #5
natecr
Thanks guys. Should i get a prop valve from the same car?
Old 10-28-2013, 12:14 AM   #6
Captainfab
60-66 Nut
You can use the Corvette prop valve,or just add anadjustable valve in the rear line. That way tou can fine tune the braking if the rear is grabbing too soon. I like the Wilwood # 260-11179 valve.
http://www.summitracing.com/parts/wi...1179/overview/
Thread Tools
Display Modes
