Old 10-23-2013, 12:27 PM   #1
BigElittleg64
BigElittleg64's Avatar
Trans Question
I have a 700r4 I believe out of a 1992 or1992 chevy pickup. I have heard that since it has the kickdown cable it will work on my 64 with out haveing a computer to run it. If that is the case there is a electrical connection on the tail shaft housing that goes to some module. Will this trans still work on my truck and what do I need to make it work. Any Help will be great Thanks.
BigElittleg64 is offline   Reply With Quote
Old 10-23-2013, 07:58 PM   #2
donthekawguy
donthekawguy's Avatar
Re: Trans Question
The connection might just be a low fluid sensor or something like that. The 700r4 doesn't have a computer. The TV cable takes a special mount on the carb. Check youtube for videos on how to hook it up.
66 shorty
donthekawguy is offline   Reply With Quote
Old 10-23-2013, 08:46 PM   #3
brokenspoke
brokenspoke's Avatar
Re: Trans Question
Check out (bowtieoverdrives) all your questions answered there
brokenspoke is offline   Reply With Quote
Old 10-23-2013, 08:54 PM   #4
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Trans Question
I think the earlier 700r4's are the ones you want with out the computer.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-23-2013, 09:15 PM   #5
Hx16457
Hx16457's Avatar
Re: Trans Question
The connection is for pwr and ground. Inside the trans pan there are some electrical components. I put the bowtie converter lockup kit in mine so that when I reached 4th gear my rmps would drop as a normal OD trans does, thus I had to add power and ground.
Don't worry about it too much. If you want the rmp drop then get the bowtie kit. It comes with everything you need and instructions on installing components.
Oh, @ 40mph I hit 4th with OD locked, rmps drop to 22!
People who make excuses didn't want to do it in the first place!
http://s1326.photobucket.com/albums/...cpZZ1QQtppZZ16
Hx16457 is offline   Reply With Quote
Old 10-24-2013, 12:21 AM   #6
Captainfab
60-66 Nut
Re: Trans Question
The 700R4's do not have a kickdown cable. It is a TV (throttle Valve) cable. It is absolutely critical that that cable is properly connected to the carburator and adjusted to produce proper pressueres inside the trans. If it is not, the trans will burn up in a short time. There is also a square electrical connection for the torque converter lockup. That is also important to be connected and operating correctly. The electrical connection on the tailshaft would be for the speedometer.
I agree with either calling Bowtie overdrives, or going to their website.
http://bowtieoverdrives.com/index.shtml
Old 10-24-2013, 08:04 AM   #7
BigElittleg64
Re: Trans Question
All good things to know I Thank all of yoou for yor knowledge.
Thread Tools
Display Modes
