Old 10-24-2013, 09:02 PM   #1
Mr.Hyde
welding truck
well I'm looking to turn my 1968 c10 half ton into a welding truck and was wondering what the pay load is with the overload springs? If anyone else has suggestions to do this feel free to throw in your input! I know I'm thinking flat bed aswell.
1968 Chevy C10 build - http://67-72chevytrucks.com/vboard/s...d.php?t=546713
Member of tailgate association of manitoba
Mr.Hyde is offline   Reply With Quote
Old 10-24-2013, 09:40 PM   #2
hugger6933
Re: welding truck
The 1/2 ton truck is not heavy enough to carry a flat bed with all the needed equipment for a welding truck, you will be way overloaded. Not only do you have to consider hauling but stopping as well and the bigger trucks of course have bigger brakes. It is not only your safety that I am concerned about but others on the road as well, if that thing id loaded and light in the front, it could easily sway into traffic. Jim
hugger6933 is offline   Reply With Quote
Old 10-24-2013, 09:49 PM   #3
Mr.Hyde
Re: welding truck
oh i agree i was the thinking the same thing thats why i thought i would ask some one more familiar. but if i were to run the long bed normally what would the payload be?
Old 10-25-2013, 09:29 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: welding truck
I think you're going about this backwards.Maybe you should get a weight of the equipment you want to carry and see if a 1/2 ton is anywhere near that.1/2 ton is 1000 # and that isn't much in the terms of welding equipment.Also consider the wear and tear.If you load a 1/2 ton to max,it will not last nearly as long as a 1 ton loaded 1/2 way.This doean't even take into account that you will need to hual materials and steel ain't light.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 10-25-2013, 09:41 AM   #5
leftybass209
leftybass209's Avatar
Re: welding truck
I don't know what you envision your end product as but I'd say this rig is more than capable of melting metal. http://www.customclassictrucks.com/f...69_gmc_pickup/
leftybass209 is offline   Reply With Quote
Old 10-25-2013, 10:08 AM   #6
bodydropped68
bodydropped68's Avatar
Re: welding truck
When I saw this post that is the truck I thought of love that truck.
bodydropped68 is offline   Reply With Quote
Old 10-25-2013, 12:49 PM   #7
Mr.Hyde
Re: welding truck
That looks awesome! Seems like they just beefed up the suspension.
Old 10-25-2013, 01:14 PM   #8
Spartan
Spartan's Avatar
Re: welding truck
If you are set on the 1/2 ton consider leaving the bed and investing in towing and electric brakes. With a good inverter and stick/tig skills you can do a lot. I recommend a trailer because a common price point for steel is 20'.
I use a jeep Cherokee and a trailer and various welding cutting rigs and it works fine except for really big structural stuff. Gotta love inverter tech.
2 cents
'69 K20 350/4 speed/Rockwell/D44/HO52.
"orange rhymes with door hinge"
Spartan is offline   Reply With Quote
Old 10-25-2013, 02:24 PM   #9
boynton
boynton's Avatar
Re: welding truck
personally I would go 3/4 ton 4x4 but I live in the sticks so my purposes would be a little different-mud/farm roads ect. It really depends on what you really want to do with it and where it will need to travel. The above mentioned truck looks sweet and if it never leaves the road could probably serve as a decent truck, but I think that truck is a little more for show than use. (the mention os going to sema/powertour). I am sure it is amazing advertising though! Who doesn't like a 67-72? Good luck with the project! can't wait to see how it turns out.
Just trying to figure this out...
1970 SWB Step-Side
http://67-72chevytrucks.com/vboard/s...d.php?t=552980 1970 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=584499
1970 SWB One Owner Step Side 6.0 LY6/6L90
http://67-72chevytrucks.com/vboard/s...d.php?t=617630 Junkyard's 1971 short wide
http://67-72chevytrucks.com/vboard/s...86#post7531186
boynton is offline   Reply With Quote
Old 10-25-2013, 02:52 PM   #10
Mr.Hyde
Re: welding truck
I'd rather have a 1 ton dually but I don't have 60k I have 2 half tons so I thought why not and I was thinking air ride in the rear with disc brakes in the front to bump up the stopping it's a long bed and again does anyone have a source or know the amount of weight you can have with overload springs?
Old 10-25-2013, 04:21 PM   #11
Mr.Hyde
Re: welding truck
Oh and what I would be runnin is a lincoln 305g(550lbs) air compressor(est 100lbs) and carious tools (est 100lbs) if I'm running a normal fleetside bed
Old 10-25-2013, 05:35 PM   #12
leftybass209
Re: welding truck
As far as spring rates go check here. May not be exact but it gives you an idea. I still wouldn't max a beds payload out with helpers. I look at helpers as insurance, or rather assurance that your leafs or coils won't buckle.
Old 10-25-2013, 06:31 PM   #13
Mr.Hyde
Re: welding truck
I think it was 1250 a rear spring any good tricks or beefing up the suspension? I'm now curious if this is possible when I get the machine I will for the most part be a weekend warrior to start
Old 10-25-2013, 07:29 PM   #14
leftybass209
Re: welding truck
If you use leaf springs get the heavy duty versions with helpers of course. I'd also get shock relocation mounts. With coils I'd swap the trailing arms. Factory is fine but I have seen them rot and separate. Same with those though, heavy duty coils and shock relocation mounts. Polyurethane bushings because of the given constant weight as well.
Old 10-25-2013, 09:33 PM   #15
Re: welding truck
I can't see anything less than a 3/4t as a welding rig. That's why they made 8-lug trucks the same size as 5 and 6. The 8-lug ones are for commercial duty. You want a full floating rear and all the other benefits of larger axles,bearings,and brakes
Old 10-25-2013, 09:40 PM   #16
Mr.Hyde
Re: welding truck
on another forum people have mentioned using a 1/2 ton for a welding truck but short term due to strain on the vehicle. only other option is using my 09 sierra ext cab slt
Old 10-27-2013, 11:21 AM   #17
Mr.Hyde
Re: welding truck
so can anyone suggest a good air ride kit that i can use to bump up my payload and Im guessing any front disc kit would be fine or are other prefered?
Old 10-27-2013, 11:53 AM   #18
Scott>72-GMC
Scott>72-GMC's Avatar
Re: welding truck
My uncle ( welder for 25 years ). Used a 2005 half ton for his welding rig flat bed used air suspension in the back Never had any issues Just letting u know. Now me I have 3/4 ton I don't weld I just like having the 3/4 ton so I know I can haul I've way overloaded 1/2 tons before no issues so I can't think ill ever overload a 3/4 ton
72 GMC super custom.
Scott>72-GMC is offline   Reply With Quote
Old 10-27-2013, 06:14 PM   #19
Mr.Hyde
Re: welding truck
Cool I appreciate all the input it seems like my weight will probably be around
900lbs give or take 100lbs with air tools compressor and welder, if I haven't forgotten anything
Thread Tools
Display Modes
