Old 10-25-2013, 04:23 PM   #1
1966burb
1966burb's Avatar
Jasper engine?
Anyone used Jasper Engine for rebuilding of engines? Thinking about sending my original 327 to them for a complete rebuild.
1966burb is offline   Reply With Quote
Old 10-25-2013, 04:31 PM   #2
j.kirn
Re: Jasper engine?
Ihave used them for a 292 cu in., very pleased . I have 60,000 on it and still runs strong
j.kirn is offline   Reply With Quote
Old 10-25-2013, 04:59 PM   #3
Wrenchbender Ret
Re: Jasper engine?
When I had a shop that is the only reman I would sell. The others would get you in trouble. There warranty handling is excellent, but very seldom is needed.
Wrenchbender Ret is offline   Reply With Quote
Old 10-25-2013, 07:24 PM   #4
Sharps40
Re: Jasper engine?
Any crate motor is better than the rebuilt or tired original engine it came with. Based on recent personal experience I just bought an ATK reman 250 I6 for my 65 C10 to replace the 71 Olds 250 that came installed in John Lee.......
This is what I learned on Monday, 0610 AM, 3/4 miles from the house at 35 mph and accelerating to the 3rd gear shift.....when the rebuilt engine (under 8K miles) dropped a valve and bent a rod/chewed itself up inside.......
Richie's First Law of Rebuilt Engines:
If the Prior Owner says the engine was rebuilt.......you can ALWAYS be sure that it will EXPLODE shortly after you decide it is TOTALLY reliable.
Sharps40 is offline   Reply With Quote
Old 10-25-2013, 07:41 PM   #5
McCoyAZ
McCoyAZ's Avatar
Re: Jasper engine?
I have a Jasper crate motor in my F150 (sorry) that has about 40K miles on it now quite happy with it no problems at all.
McCoyAZ is offline   Reply With Quote
Old 10-25-2013, 08:20 PM   #6
66Submarine
66Submarine's Avatar
Re: Jasper engine?
Lol, that's exactly why I like to put all my stuff together myself. Too many butchers out there. FWIW, I'll take an old worn out engine that hasn't been messed with over a "freshly rebuilt"(molested) one any day of the week.
Which I guess would be my personal suggestion, to put it together yourself. That's the only way you really know it's right, IMO. Maybe I'm paranoid, but then again, my "rebuilt" 292 had 13 pushrods....
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Old 10-26-2013, 12:08 AM   #7
Captainfab
60-66 Nut
Re: Jasper engine?
If you are going to send in your original 327 to them to get rebuilt, I would suggest marking all the major parts, ie: block, heads, crank,etc., so that you can verify that you do indeed get your original engine back. Since a 327 is a somewhat desireable engine, someone along the process may decide to pull the 'ol switcheroo, and fingure you wouldn't know the difference. I have heard of it happening before.
Old 10-26-2013, 09:48 AM   #8
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: Jasper engine?
I have a very good friend who has a shop and uses jasper engines and rebuild service. He has only had 2 problems with a motor from them and both were handled very quickly and without any issues. He has installed A LOT of engines too. They are not cheap mind you, but do you want cheap or good? cuz you wont get both.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 10-26-2013, 09:57 AM   #9
rideblue00
rideblue00's Avatar
Re: Jasper engine?
Have you asked around if there are any local reliable shops? I had a local guy do mine and i also had him run it on his dyno. I got to watch him dyno it and he was a little liberal with the throttle, lol But anyone i talked to said he was a good builder and did lots of race engines(mostly circle track stuff) People said he was always swamped with work. I just wouldn't want to pay the shipping fees if i can get stuff done local.
rideblue00 is offline   Reply With Quote
Old 10-26-2013, 02:08 PM   #10
Sharps40
Re: Jasper engine?
Free shipping on my new long block/crate motor. Buy local, venders can often cut you a break....mine came free shipping, $150 price discount, $50 in coupon for anything else I want to pick up, 5 qts penzoil, Wix Filter and Supply of GM Blue Hi Temp engine paint. I'm quite pleased at not having to look for a local builder (nearest is 50 miles cause NAPA don't anymore) and not havin to deliver, pick up, pull, replace, rent tools, skin knuckles, etc. In the long run, it'll be much cheeper than all that work tryin to fix the existing long block.
Old 10-26-2013, 02:23 PM   #11
61_FL_Apache
Who Me?
61_FL_Apache's Avatar
Re: Jasper engine?
I hear a lot of good things about Jasper, but I would rather go local as rideblue mentioned.
Steve
1997 Tahoe LT 4D 2WD (DD)
2001 Blazer 4D 2WD
1961 Apache 10 (sold)
1965 C10 Stepper (sold)
61_FL_Apache is offline   Reply With Quote
Old 10-26-2013, 02:58 PM   #12
T2vigil
T2vigil's Avatar
Re: Jasper engine?
I like having my old motors rebuilt if it is not in pieces and was running. The reason being you know what you started with, many heat and cool cycles abused or otherwise. If it magnafluxes out with no cracks rebuilt it. Weather you send it off or have it done locally I would definately stensil or otherwise mark the heads block and crank and tell them it is marked so you get your "Prestressed" part back.
T2vigil is offline   Reply With Quote
Old 10-28-2013, 01:22 AM   #13
1966burb
1966burb's Avatar
Re: Jasper engine?
Thanks for all the input. Yes, I would mark all my parts before sending them out and make sure everyone is onboard as to what I expect to get back. j
Old 10-28-2013, 03:31 PM   #14
cg285
Re: Jasper engine?
we have always done our own engine/machine work in house but at one period of time, years ago, we started using jasper engines to free-up some of our time. we had enough issues with them that we went back to doing it all in house. timing gears put in wrong, cracked heads...
at the same time we tried using their transmissions, for the same reason, and none of them made it off the lift. i tried to tell them what they were doing wrong but they wouldn't listen.
this was over 10years ago. maybe they are better now
cg285 is offline   Reply With Quote
Old 10-28-2013, 04:58 PM   #15
Wrenchbender Ret
Re: Jasper engine?
this was over 10years ago. maybe they are better now[/QUOTE]
Yes. They made a complete about face several years ago. I had a lot of trouble with them years back.
Thread Tools
Display Modes
