Old 10-27-2013, 02:46 PM   #1
bigmac73
bigmac73's Avatar
power brake conversion
I am buying a summit power brake kit P/N CLP-6772BB2-11 , it comes with everything except the pedal rod, how much of a difference in length is the power brake set up than manual, i thought i would just lengthen my older one and use it
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-28-2013, 12:24 PM   #2
Lou Boffa
Lou Boffa's Avatar
Re: power brake conversion
interested
Figure out what you want--then figure out what you are willing to give up to get it.
Lou Boffa is offline   Reply With Quote
Old 10-28-2013, 05:05 PM   #3
hugger6933
The man. set up on the m/c has the rod kinda made on to it similar to that of a later booster. the booster has a lot longer rod because it is mounted way out on the firewall with that weird bracket thing between the fw and the booster. If you are mounting the booster flush on the fw like a late model would so it looks better the rod of course would then be shorter but by how much it is a trail and error thing unless [and I don't ]have measurements
hugger6933 is offline   Reply With Quote
Old 11-14-2013, 05:01 PM   #4
bigmac73
bigmac73's Avatar
Bump to see if i can get any more info
Mike
Old 11-14-2013, 07:36 PM   #5
mgchevyparts
mgchevyparts's Avatar
The Summit pic is incorrect, you'll get a repop of the orig 11" booster set up. It'll bolt right up to your truck. The rod is part of the booster.
1957 CHEVY 1/2 TON SHORT BED
1940 FORD 1/2 TON SHORT BED
mgchevyparts is offline   Reply With Quote
Old 11-14-2013, 08:20 PM   #6
stevenbear72
stevenbear72's Avatar
post up a pic once its mounted. I also just have a MC and want to add a booster to my truck.
68' Cst10 w/69 front, 5.3/4L60e swap, 12 bolt 4.11's
Project "Huckleberry"
68 GMC K1500 1/2 ton L83/6L80e
stevenbear72 is offline   Reply With Quote
Old 11-14-2013, 10:13 PM   #7
hugger6933
Go to the upper left hand corner of the home page of this site, and then click on tech tips and then go to our trucks 67-72 and there you will find a post about changing to power brakes on trucks that are not so equipped. There is a wealth of info in the tech tips sections both the trucks and the paint and other that are broken down so when you get a chance drop in there and see whats up. You will be so glad that you did, you will be glad you did and maybe even your truck will thank you. Jim
Thread Tools
Display Modes
