Old 10-27-2013, 08:40 PM   #1
bigmac73
bigmac73's Avatar
Air Shocks
Anybody run air shocks on the rear and if so what is the normal PSI (unloaded bed) do you run in them??
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 10-27-2013, 10:02 PM   #2
FirstOwner69
FirstOwner69's Avatar
Re: Air Shocks
Had some on my 69. There was a ring around the valve saying min 25# and, I think, max 150#.
FirstOwner69 is offline   Reply With Quote
Old 10-27-2013, 10:18 PM   #3
LONGHAIR
Re: Air Shocks
The upper mounting is somewhat of a weak point even with regular shocks, plus the shocks were never intended to support the weight anyway....so I would seriously consider reworking them to get the bolts into a "double-shear" situation.
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Thread Tools
Display Modes
