Old 10-28-2013, 01:45 AM   #1
1966burb
1966burb's Avatar
66 327 fuel pump number
Does anyone know the correct AC fuel pump for a 66 with a 327? I know that is probably a four digit # stamped on the mounting flange. Plus pump is bolted together instead of crimped. Collecting up all the parts so I can put the original 327 back in some day.
1966burb is offline   Reply With Quote
Old 10-28-2013, 10:44 AM   #2
60-66
60-66's Avatar
Re: 66 327 fuel pump number
Here's what I've come up with searching through a 1966 GM parts book and a 1970 Chevy parts book and history book. This first one I believe is assembly line correct and was discontinued around 1968 according to my parts history book. According to the parts book description it fits "ALL 283 327 and 409 with FOUR barrel carb".
5621665 4657 http://www.ebay.com/itm/65-1965-Corv...#ht_185wt_1162
This one was the replacement after 1968. 6415616 40018 http://www.ebay.com/itm/NOS-1959-196...ht_1061wt_1162
If anyone has information to the contrary Im all ears, it would be nice to see an original.
IS IT an EATON or Chevrolet rear axle https://67-72chevytrucks.com/vboard/...d.php?t=843778
The hubcap thread http://67-72chevytrucks.com/vboard/s...d.php?t=702839
WANTED : 1963-1966 6 Cylinder Fan Shroud
WANTED :1964-1966 PANEL TRUCK
60-66 is offline   Reply With Quote
Old 10-28-2013, 12:09 PM   #3
1966burb
1966burb's Avatar
Thanks, I will have to start looking for a core to rebuild. The corvette guys go nuts on Ebay on that stuff. I should know as I did a numbers matching 61 fuelie years ago.
Thread Tools
Display Modes
