10-29-2013, 10:10 PM | #1 |
Let's see some pics of 4-6 and 5-7 drops on 71-72 c 10
I want to get some idea's on if I want to go 4-6 or 5-7 on my 71 gmc with leaf springs on the rear I will probably keep these 15x8 ralley's until I can afford 20x8 and 20x10 torq thrust II
10-29-2013, 10:55 PM | #2 |
Re: Let's see some pics of 4-6 and 5-7 drops on 71-72 c 10
Please help my sister in law with her battle with cancer https://gofund.me/902f6fce Thank you all so far you are angels!! Project "C10 Fever" (68 factory black 396 swb) Project "Little Sister" (70 c10 blue original paint refresh) Project "Blue Bomb" (70 c30 blue original paint refresh) SOLD Project "Vitamin C" (71 c10 orange original paint refresh) SOLD |
10-29-2013, 11:03 PM | #3 |
Moderator
5/7
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul Last edited by leddzepp; 10-30-2013 at 12:33 AM. |
10-29-2013, 11:06 PM | #4 |
Moderator
Other side
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed. 1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck. RIP ElJay RIP 67ChevyRedneck RIP Grumpy Old Man RIP FleetsidePaul |
10-29-2013, 11:09 PM | #5 |
This should give you a good idea, very similar to what your lookin for
Scott 67 c10 sold 89 c1500 90 k2500 91 s10 #chevyonly |
10-29-2013, 11:49 PM | #6 |
1972 C10 LWB- 4.5 Front and 5 Rear Drop, 406/TH350 1966 Caprice 1968 Impala (Frame Off LSX Project) 2001 Tahoe LT 2013 Hyundai Elantra 2010 Kawasaki Z1000 |
10-30-2013, 12:14 AM | #7 |
Are these drops just done with springs, or is there more to it so that you can still get a proper alignment after the drop?
______________________ www.northeastrodrun.com |
10-30-2013, 12:25 AM | #8 |
Moderator
2.5" dropped spindles in front (no change to geometry), combined with one cut coil on each original spring for another 2.5-3". Added one additional shim to each mounting point on the upper control arms. Aligned perfectly and drives straight down the road. 5" drop springs combined with 2" blocks in the rear.
10-30-2013, 12:51 AM | #9 | |
10-30-2013, 07:36 AM | #10 |
Tot Roddin'
4.5/6 ECE drop with NO c-notch installed.
-Nate 1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6) 1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior) 2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package) |
10-30-2013, 09:11 AM | #11 |
Installed the ECE kit a few months back. Total drop of 4/7 to even out the stance. Added a 1" lowering block in the rear. C-notch to follow.
17" TTII's w/ 255/55/17 on all 4 corners |
10-30-2013, 11:38 AM | #12 |
Moderator
Thanks. Yes you need to c-notch for clearance. Even with CPP 5" springs I bottomed out all the time and it needed then. Opinions and numbers seem to be all over the place as to when it is "required". I recommend installing the springs and using your own judgement.
10-30-2013, 12:28 PM | #13 | |
1970 C-10 LWB "Blu" Instagram (current build pictures) 70_nc_c10 |
10-30-2013, 12:53 PM | #14 |
Moderator
I wouldn't go any lower than this with 15" wheels...it's very close!
10-30-2013, 12:57 PM | #15 |
71 GMC 1500 with 2.5 CPP Spindles, 1" CCP Spring, DJM Flip Kit 5" FK1012-5 for 2.25" leaf spring. Supposedly 3.5/5 more like a 4/6. 20x8 OldSkool with 275/45 Falken Ziex TZ04. The front has settled a little more since these pics after doing the ball joints and getting the springs seated properly.
Life is too long to go slow... 71 GMC 1500 Super Custom LWB 350/350 AC(replaced w/vintage air)/PS/PB 2.5 CPP Spindle, 1" CPP Drop Spring, CPP Front and Rear Sway Bars/DJM Flip, new General Spring KC 5 spring pack, HEI /IntReg Alt 20x8.5 OldSkools 5" BS, 275/45 Falkens |
10-30-2013, 04:40 PM | #16 |
Its not a 4-6 or 5-7 but here is a 6-8.
10-30-2013, 06:30 PM | #17 |
Lowering mine this weekend. Ill post before and after pics when its done.
I know yellow isn't for everyone, but I really like that yellow.
71 swb 350/4sp manual 5/7 static drop |
10-30-2013, 08:43 PM | #18 |
nice truck shopking. i havent seen that one around the forum for some reason.
72blackbeauty, roger, c10dreamin can you guys fit 20's? your stances are perfect. |
11-04-2013, 12:49 PM | #19 |
Shopking72 your truck looks great! What color is that gunmetal grey? Is it a chevy color?
1972 c10,2wd,long bed,250,4spd----> 1972 SWB Fleetside 4x4 12v Cummins build thread http://67-72chevytrucks.com/vboard/s...d.php?t=513791 |
11-04-2013, 01:46 PM | #20 |
I haven't got to that point yet of seeing if 20's would fit, but I dont see any reason they wouldn't. only thing i would have to take into consideration is tire sizes for front and rear.
11-04-2013, 01:48 PM | #21 |
11-04-2013, 01:53 PM | #22 |
What the heck, one more 4.5/6 on Intro's Vista 20/22 combo.
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
11-04-2013, 01:54 PM | #23 |
I have 20x8 front and rear. Rear is 6" spring with 2" block
11-04-2013, 02:41 PM | #24 |
There are some sexy trucks here.
11-04-2013, 03:15 PM | #25 |
Here is mine with Boss 338 wheels, 20 x 8 front and 20 x 10s rear.
1972 Chevy short bed ZZ4 350/355hp GMPP crate engine. 1972 Cheyenne K-20 454/400hp big block 1988 Jeep Wrangler 2010 Jeep Sport Unlimited |
Thread Tools | |
Display Modes | |
