Old 10-30-2013, 09:48 PM   #1
61K10
61K10's Avatar
foot pedel info
rebuilding my petal assembly--the clutch cross shaft that goes through the brake tube. is there any plastic bushings like in the brake pedal shaft? my clutch shaft is loose in the brake pedal shaft? new plastic bushings in the main brake pedal shaft. any info app.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 10-30-2013, 10:35 PM   #2
'63GENIII
'63GENIII's Avatar
Re: foot pedel info
My brake pedal shaft had em on either side. The clutch didn't. Just grease IIRC.
Chris
'63 k15 long step
Vortec 7.4 - L29 Blackbear tune, Five 0 Motorsports injectors, Chris Straub Cam, NV4500, divorced 205
52" front and 63" rear spring swap
D44 / 14bff - disc axles
Milemarker 9K and 10.5K hydraulic winches
63" & B52 Spring Install http://67-72chevytrucks.com/vboard/s...ng+swap+thread
NV4500 Reverse Build Thread http://67-72chevytrucks.com/vboard/s...=reverse+build
L29 - 7.4 Vortec Build http://67-72chevytrucks.com/vboard/s...&highlight=L29
'63GENIII is offline   Reply With Quote
Old 10-31-2013, 12:14 PM   #3
61K10
61K10's Avatar
Re: foot pedel info
thanks for the reply 63GEN. mine was froze up. po just took the stop bolt out on the sleeve so the clutch would work. didn't look like it was ever apart. seems to me it should fit a little tighter. how much play was in yours?
1961 chevy K10
Thread Tools
Display Modes
