Old 11-01-2013, 07:13 PM   #1
draggin49
worth the trouble to run x pipe on non performance application??
For all the extra $$$ I'd have to spend at an exhaust shop on labor in pipe bending/labor to run a bassani x pipe I have laying around.
My truck has a gm crate motor, I'm guessing in the 260-275hp range
I know its much simpler to run it straight back through the carrier with NO x pipe
Just dont wanna go to a lot of $$ /trouble if the x won't be worth it
Any input would be great.
draggin49 is offline   Reply With Quote
Old 11-01-2013, 08:33 PM   #2
elf w/capital T
Re: worth the trouble to run x pipe on non performance application??
From what i have researched, it will all matter on how much you are concerned about the sound, since hp isnt too crazy, but im sure theres more someone here will chime in with...good luck and have fun!!
elf w/capital T is offline   Reply With Quote
Old 11-01-2013, 09:34 PM   #3
I've never run an x-pipe on anything.
Old 11-01-2013, 10:28 PM   #4
mmiddle
mmiddle's Avatar
X-pipes and cross overs are beneficial on sound and balance. The performance benefit is generally only valuable above say ~4000ish rpm. X-pipes like headers help scavenge the cylinders at upper rpms. They are cool looking, but few of us really need x-pipes. A simple crossover pipe will help tame the exhaust note and is more likely what you want.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 11-01-2013, 10:41 PM   #5
draggin49
Thanks so much guys for clarifying!
She will be on the road for the first time in 15 years next week. Should be fun.
Old 11-01-2013, 10:50 PM   #6
swamp rat
swamp rat's Avatar
Most of the shops around here say to just run an H pipe to balance the sound.
Mike.
Swamp Rat build thread :
http://67-72chevytrucks.com/vboard/s...d.php?t=595019
72 3/4T 4X4
4" BDS Lift
33" BFG's
swamp rat is offline   Reply With Quote
Thread Tools
Display Modes
