Old 11-02-2013, 05:43 PM   #1
NC_John
NC_John's Avatar
3" drop all around and not sitting even
I finished the 3" drop on the hind end of the truck and its level but not sitting even. Before or after.... I was hoping it was a bad coil making the truck sit crooked but with new springs all around, its still not even.
Before the drop (measured from top of wheelwell)
Right Front - 32.75"
Left Front - 32.25"
Right Rear - 33.25"
Left Rear - 33.00"
After the drop (3" front, 3" rear, springs....)
Right Front - 30.5" (-2.25")
Left Front - 29" (-3.25")
Right Rear - 31.75" (-1.5"
Left Rear - 30.75" (-2.25")
Not sure why its not sitting level but its starting to piss me off.
Any ideas on what I can check??
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 11-02-2013, 05:55 PM   #2
leddzepp
Moderator
leddzepp's Avatar
Re: 3" drop all around and not sitting even
Frame is probably tweaked. Very common issue with these 40 year old trucks.
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
leddzepp is offline   Reply With Quote
Old 11-02-2013, 06:05 PM   #3
Mister-B
I'm probably oversimplifying this, but sometimes that's the first thing to check. How's your tire pressure? Is it correct on all tires? Are all tires the same size, make, and brand?
Mister-B is offline   Reply With Quote
Old 11-02-2013, 06:18 PM   #4
Sicklajoie
The Niner
Sicklajoie's Avatar
Are the springs sitting in the pockets ok?
"A good racer is one whose head is in communication with his balls." - Richie Evans
1970 C/20 - 402/TH400/3.54s - 74K miles
2003 GMC Sierra 2500 - Wheatland Yellow
Niner Progression Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=697183
Classic Trucks article: https://www.motortrend.com/features/...et-c20-driven/
Sicklajoie is offline   Reply With Quote
Old 11-02-2013, 06:36 PM   #5
cdowns
cdowns's Avatar
i've had close to 25 of these trucks over the years almost all had tweaked frames it is a very very very common issue with chevy trucks
Old 11-02-2013, 08:58 PM   #6
Tinkermc
Not an uncommon problem, but was it even be4?
Tinkermc is offline   Reply With Quote
Old 11-02-2013, 09:18 PM   #7
ksshane
ksshane's Avatar
maybe drive it for a couple of days and see if one side settles... it may just need to seat into the pocket.
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 11-02-2013, 09:43 PM   #8
NC_John
NC_John's Avatar
Well sh*t.... I didn't want to hear that. Does it need to go on a rack and get untweaked? Is that what you guys did?
1970 C-10 LWB "Blu"
Old 11-02-2013, 09:47 PM   #9
NC_John
NC_John's Avatar
I did check the tires out and make sure my guy gave me 4 of the same size. For this kind of height difference a tire would about have to be flat!
All the springs seem to be seated properly.....
It was crooked before- the pics I took at the meet we had a few weeks ago, before I did any lowering, had it sitting funny then.
I've got a buddy with a decent sized body shop. I might see what he wants to put it on the rack to see what's up.
Always something.....
1970 C-10 LWB "Blu"
Old 11-02-2013, 11:15 PM   #10
Sklptrljay
Sklptrljay's Avatar
I had a tweaked frame. I found the lowest spot on the rail, jacked it up and put a jackstand in that spot and left it overnight. It took an 1.5"*out and got all 4 corners to within a .25".
Hope it's as simple to fix for you.
Sklptrljay is offline   Reply With Quote
Old 11-03-2013, 06:20 AM   #11
NC_John
NC_John's Avatar
That sounds like its worth a try. Boy, that'd be awesome if it worked. I don't like this truck sitting crooked.
1970 C-10 LWB "Blu"
Old 11-03-2013, 08:15 AM   #12
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Here's the measurements from my 69 before and after drop (4.5/6") and after a wheel change (15" to 20"). You can see that even my truck isn't 100% "level".
Was your measuring surface level?
Before the drop:
Driver's Side Front: 33 1/2"
Driver's Side Rear: 33"
Passenger Side Front: 33 1/4"
Passenger Side Rear: 32 7/8"
After the drop:
Driver's Side Front: 28"
Driver's Side Rear: 29"
Passenger Side Front: 28 1/4"
Passenger Side Rear: 28 3/4"
After the new wheels (4/3/10):
Driver's Side Front: 28 7/16""
Driver's Side Rear: 29 5/16"
Passenger Side Front: 28 1/2"
Passenger Side Rear: 29 5/16"
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 11-03-2013, 09:28 AM   #13
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Don't put a level on your house.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-03-2013, 10:25 AM   #14
NC_John
NC_John's Avatar
LOL- this house is good..... the last one, not so much. I found that out when I was working on some finishing trim.
1970 C-10 LWB "Blu"
Old 11-03-2013, 11:24 AM   #15
gvw5400
gvw5400's Avatar
OR a square!
gvw5400 is offline   Reply With Quote
Old 11-03-2013, 11:36 AM   #16
jhwkns
Registered Cruiser
jhwkns's Avatar
It cost $250 to have my frame straightened. One of the horns was tweaked pretty bad. It was money well spent.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
Old 11-03-2013, 04:52 PM   #17
NC_John
NC_John's Avatar
The issue isn't so much that the truck isn't sitting 100% level- the issue is it is really noticeable and is driving me nuts. That left front corner sagging is the first thing I see now when I look at the truck.
I am doing all my measurements on a finished concrete floor in my garage so its pretty level.
1970 C-10 LWB "Blu"
Old 11-03-2013, 04:53 PM   #18
NC_John
NC_John's Avatar
I might try the overnight on an stand first, failing that, its off to see my man at his shop. If these frames are so jakey, how are guys not twisting them into pretzels with built engines?
1970 C-10 LWB "Blu"
Old 11-03-2013, 05:22 PM   #19
leddzepp
Moderator
leddzepp's Avatar
The frames arent jakey, that's just what 40 years of use does to a truck, lol.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
Old 11-03-2013, 09:50 PM   #20
NC_John
NC_John's Avatar
Yeah, but I want another 40!
1970 C-10 LWB "Blu"
Old 11-05-2013, 07:44 PM   #21
robozride
I wouldn't think it is a frame issue, your measurements were very close before you dropped it so I would check that the springs are in the pocket completely.
robozride is offline   Reply With Quote
Old 11-05-2013, 08:22 PM   #22
NC_John
NC_John's Avatar
Here is a before shot- this is before any lowering, which to me, takes out mis-seated springs as the issue-
Funny how the truck beside mine (the 66) is in a sympathetic lean on the passenger side....
And here is after the front drop- I haven't got one of it with the rear done yet but it still sits the same.
1970 C-10 LWB "Blu"
Old 11-06-2013, 03:55 PM   #23
long'n low
long'n low's Avatar
Mine leaned like yours, i added 1/2" block to the high side between trailing arm and axel. Evened out my lean quite well.
Also you can try and swaping the springs from side to side, this might help.
long'n low is offline   Reply With Quote
Old 11-06-2013, 03:59 PM   #24
67ChevyRedneck
67ChevyRedneck's Avatar
Maybe a very large fella drove it for a long time?
Could be a lot of things. Might not even be the frame. How do your cab and core support mounts look?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-06-2013, 04:04 PM   #25
NC_John
NC_John's Avatar
I thought about shimming the rear axle.... I want to lower it some more back there anyway. The springs are brand new in all four corners (zero miles) and since the old ones did it, I'd say that is not the culprit.
Seat feels pretty good,
And replacing the coils would have fixed tired parts I'd think.
The cab and core mounts look pretty solid but I can check them again. I'd think if one was bad enough to cause that lean, I'd feel or hear it when riding (and I've not).
Thanks guys.
1970 C-10 LWB "Blu"
Thread Tools
Display Modes
