Old 11-03-2013, 09:58 AM   #1
Gigem
Gigem's Avatar
Sticky door locks
I am close to the bottom of my "to do" list on this truck, which is a good thing!
Small issue with door locks... They stick... When I go to unlock either door, I can't turn the key at all unless I first press the thumb button on the handle...
Any idea how to tackle this? I assume I need to take door panels off and lube something, but I am not exactly sure what...
Any suggestions? Thanks!
1972 GMC Sierra Grande (current truck)
1980 Chevy Stepside (gone)
1987 Chevy Blazer (gone)
1972 Chevelle SS Convertible (gone)
1973 Chevy Corvette (gone)
1967 Chevy Camaro (STOLEN!)
Gigem is offline   Reply With Quote
Old 11-03-2013, 02:25 PM   #2
walkerb
walkerb's Avatar
Re: Sticky door locks
I would lube everything. Handle, lock inside and out. Also while moving and turning everything while spraying.
1973 k20 Suburban 350
1974 Custom stepside c-10 250
1975 Chevy stepside 454
1986 K30 Crewcab SRW 350
R.I.P- glimmertwin01- board member and good friend, you will be missed
walkerb is offline   Reply With Quote
Old 11-03-2013, 04:25 PM   #3
geezer#99
geezer#99's Avatar
X2. Spay the latch inside and out with graphite spray like in this link.
http://www.blastercorporation.com/Gr...-Dry-Lube.html
Old 11-03-2013, 06:03 PM   #4
tucsonjwt
I had stick door locks which prevented my electric door lock actuators from working. The problem was a corroded lock rod. You need to remove the interior door panel and lube the lock rod completely, and you may need to straighten it out a little.
tucsonjwt is offline   Reply With Quote
Old 11-05-2013, 08:12 AM   #5
TDS-MN
For me, the symptom you describe was a precursor to the door latch finally sticking completely closed. I would definitely suggest lubricating soon. It is NOT fun to have to try and remove the door panel with the door stuck shut., som eof the screws are very difficult to access with the seat in place.
I focussed my lubricating spray on the latch mechanism, inside the door, on the rear jamb of the door. Once you have the interior panel off, and if you operate the lock to lock and unlock the door, you will see the part that 'rocks' up and down. I hit that with a liberal amount of lube, and that solved my troubles.
TomS.
'98 S-10 Blazer 4dr 4wd - 4.3, AT, stock
'85 K-10 w/ 305, 700r4, np208, and RUST!
SOLD Dec 2014
TDS-MN is offline   Reply With Quote
Old 11-10-2013, 07:31 PM   #6
Gigem
Gigem's Avatar
problem solved - Dynamat does not stick to the inside of a door skin! It had all fallen down and gummed up the works in there... Lesson learned...
Thread Tools
Display Modes
