Old 11-05-2013, 02:25 PM   #1
jmorri34
jmorri34's Avatar
I'm stumped help!
Ok I know this has been hashed over a million times and trust me when I say I have researched all the other posts and I am stumped. Here goes: The infamous hard brake pedal. I changed from all drum to all disc and EVERYTHING from the pedal to the tires is brand new. I have tested everything I know to test I. E. Vacuum,booster check valve, pushrod is straight,vacuum hose is good,proportioning valve everything. I even did every test CPP says to do on their tech site and nothing, I have to near stand on the pedal to stop. The test for a stuck proportioning valve is negative, I just dont know what to do next. I keep thinking its a bad booster but didnt save the reciept for it( I know dumb me) So I cant send it back to CPP. Anyway, I wanted to see if anyone has any other ideas before I go buy a new booster so thanks for anything!
1969 cst prostreet
http://67-72chevytrucks.com/vboard/s...d.php?t=568661
jmorri34 is offline   Reply With Quote
Old 11-05-2013, 02:32 PM   #2
Longhorn 70
Longhorn 70's Avatar
Re: I'm stumped help!
does the pedal pressure required change when the engine is running/not running?
when you unplug the vacuum line to the booster, do you fell vacuum on the line with the engine running?
when you run the engine for a minute then turn it off, can you unplug the booster line and hear air rush in?
do you have a vacuum gauge that you can measure the vacuum at the booster with?
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11.
1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar
And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9
Longhorn 70 is offline   Reply With Quote
Old 11-05-2013, 02:47 PM   #3
cdowns
cdowns's Avatar
pushrods clearanced? rod from booster to master cyl and rod from brake pedal to booster both need clearances
Old 11-05-2013, 02:49 PM   #4
BugzC10
BugzC10's Avatar
Subscribed...can't be of much help, but want to here what resolves your problem. I may change out my rear drums one day.
Also..if you do determine it is the booster, still give CPP a call. They may help help you out.
How did the pedal feel when you bled the brakes after installing every thing? Good flow of fluid at the caliper fittings?
1970 C10 Short Stepper with 71/72 front clip.
BugzC10 is offline   Reply With Quote
Old 11-05-2013, 03:09 PM   #5
jmorri34
jmorri34's Avatar
Well the pedal pressure is the same engine off and on, there is alot of vacuum on the line when I unplugg it, I ran the engine and shut it off and unplugged the line again and no air rushed anywhere in or out. I dont have a vacuum guage but man this thing feels like its pulling alot of vacuum on it when I unplug the line. Im trying everything you said. thanks
1969 cst prostreet
Old 11-05-2013, 03:10 PM   #6
jmorri34
jmorri34's Avatar
I dont really know much about the pushrod clearances, can you elaborate for me so I can try and check it out, Id really apreciate anything you can tell me!
1969 cst prostreet
Old 11-05-2013, 03:12 PM   #7
jmorri34
jmorri34's Avatar
Yea I will still call them, Pedal was nill untill we bled the brakes and stiff once it was bled numerous times. Im fairly sure the fluid is not the problem, the flow was normal when bleeding also. thanks
1969 cst prostreet
Old 11-05-2013, 03:33 PM   #8
cdowns
cdowns's Avatar
should b somewere about 1/8 inch clearance for each one
the pedal rod is easy to see and feel
the booster to master ?? most guys put slly putty or clay on the rod and bolt everything togetther then unbolt and see how thick the putty is at rest
Old 11-05-2013, 03:58 PM   #9
jmorri34
jmorri34's Avatar
Ok Ill check it out thanks!!
1969 cst prostreet
Old 11-05-2013, 04:05 PM   #10
leftybass209
leftybass209's Avatar
Maybe I'm lost on how a booster actually functions but it was my understanding that if a booster fails it's like having manual brakes. In that case my truck has no booster and certainly doesn't require a lot of force to stop. I can lock the brakes up without shoving my foot in the pedal too hard. Best of luck in your search for the answer.
leftybass209 is offline   Reply With Quote
Old 11-05-2013, 04:11 PM   #11
jmorri34
jmorri34's Avatar
Man I dont think I could lock the brakes up if I tried, I have brakes but it sure doesnt seem like the booster is working to me. I know its brand new and all but I dont think its working. The weird thing is all the booster tests turn out good but it just doesnt seem to me its working, I wonder if thats even possible
1969 cst prostreet
Old 11-05-2013, 04:41 PM   #12
grayw0lf
I'm in the exact same boat on my '70 C-10. I don't think i could lock the brakes up on dry ground if i tried.
85' CUCV M1009!!! The newest addition!
6.2diesel, Th400, NP208, & only 36k miles!
70' C-10 LWB Fleetside - Looking good these days!
05' Dodge Neon
88' Winner Escape Sport 1750 - 4.3v6
94' Seadoo SP
84' Honda TRX200, bare nekkid. Just a frame & tires.
Always looking for another project or any good deal!
grayw0lf is offline   Reply With Quote
Old 11-05-2013, 04:56 PM   #13
faribran
you dont have a pinched or crimped steel line do ya ?
faribran is offline   Reply With Quote
Old 11-05-2013, 05:21 PM   #14
jmorri34
jmorri34's Avatar
No everythings brand new and bled perfectly, on the phone with CPP tech as we speak.
1969 cst prostreet
Old 11-05-2013, 05:46 PM   #15
Bigdav160
Bigdav160's Avatar
What master cylinder are you running?
My Classics:
'72 K20 Suburban + '65 Dodge Town Wagon
'72 Corvette Roadster +'67 Corvette Roadster
'73 Z-28 Camaro
'63 Ford SWB Uni Pickup
'50 Ford Coupe
Bigdav160 is offline   Reply With Quote
Old 11-05-2013, 06:42 PM   #16
Longhorn 70
Originally Posted by jmorri34 View Post
...... I ran the engine and shut it off and unplugged the line again and no air rushed anywhere in or out. ... thanks
Do you have a one way valve in the vacuum line? It should be on the end that plugs in to the booster.
Looks kinda like the one in the pic below. If you do, good. If you do unplug the end that goes into the booster and blow in it. You should be able to. Now unplug the hose from the other end. Blow into it. You should NOT be able to.
Old 11-05-2013, 08:39 PM   #17
jmorri34
jmorri34's Avatar
Yea same one as that. I actually pulled it out and you could hear the air escape. I also checked the valve and you can only do it one way so its good too. Im at a loss. CPP is helping me pretty good to so Im testing stuff with them also
1969 cst prostreet
Old 11-05-2013, 08:41 PM   #18
jmorri34
jmorri34's Avatar
This is the setup I have here, everything looks good but its just not working right!
1969 cst prostreet
Old 11-05-2013, 09:04 PM   #19
slow-1
slow-1's Avatar
I think you shoud hear the pressure/vaccum equalize when you did this...almost like popping open a cool one.
Seems to me like there is an internal leak in the booster.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 11-05-2013, 09:23 PM   #20
Longhorn 70
OK so if there is a check valve and you don't hear air rush when you remove the vacuum check valve from the booster, the booster isn't holding vacuum or there is no differential betweek the chambers of the booster.
There isn't a decal or plastic or anything covering the BACK side of the booster is there?When you unplug the vacuum line and from the booster and the engine is running, do you hear a mad rush of air going in to the disconnected end of the hose? Does the engine idle change?
Old 11-05-2013, 09:24 PM   #21
mmiddle
mmiddle's Avatar
2X!!!! The check valve is critical.
Mark
Jesus is the Way!
2003 2500HD CCLB Duramax/Ali (Clifford)
2014 2SS/RS black on black Camaro (Betty)
2006 Pontiac SOLSTICE silver/black (Lula-Bell)
1970 C/10 Short Wide (Peggy)
1964 C/10 Short Step (Hambone)
RIP Jimmy Hamilton Thank you for the trucks
mmiddle is offline   Reply With Quote
Old 11-05-2013, 09:50 PM   #22
Ole Greenie
Ole Greenie's Avatar
Well, after 3 months diagnosing my brake issues...which are mostly unrelated...I also agree that the booster may be suspect. The booster is rarely the issue though. I too have a hard pedal but that is because I have a BBC and I was looking for the clearance from the lt. head so I got a double booster. I digress...but either the internal diaphram is working or not, the check valve is working or not, or you are not pulling enough vacuum. I had to dedicate a big hose from the intake to the booster...all by itself.
Now if you have this dedicated line, and all else checks out then I'm stumped too. I'm sure you have checked but the front line out of your PV goes to your Ft. brakes and the rear accordingly. I'm inclined to think your booster is suspect, That's an 11" booster and it should do really well in boosting the line pressures!
John Paap
Ole Greenie
Hagerstown, MD
My Mistress
70 CST Short/Step
LS 5.3/4L65E
New motor install Thread:http://67-72chevytrucks.com/vboard/s...d.php?t=667773
Ole Greenie is offline   Reply With Quote
Old 11-06-2013, 12:01 AM   #23
slikside
slikside's Avatar
Have you tried this booster test:
With engine off, press/pump pedal firm and hold.
Start engine.
If pedal moves toward f floor, booster is working, if not, it isn't.
Qiuck, simple,easy, decisive.
1972 Chevy C-10, SWB, Fleet, 350/350, PS, PB, HEI, mostly stock, Survivor.
slikside is offline   Reply With Quote
Old 11-06-2013, 12:23 AM   #24
davischevy
davischevy's Avatar
Subscribed:
That looks like the same set up we put on the Blazer a while back, with the same results. We never did figure it out. We changed vacuum source, master cylinder and We finally put all the old stuff back on and it works great. The new one is laying here in a box. I know this doesn't help, but I suspect someone has built some faulty boosters. We bought our set up from a place called "performanceonline.com" and none of their troubleshooting tips worked.
davischevy is offline   Reply With Quote
Old 11-06-2013, 02:58 AM   #25
oldspowered67C10
Id be willing to bet its a bad booster, those CPP boosters are a crap shoot at best, I had 2 bad ones in a row, finally got tired of it and got one from the junkyard, works great now.
oldspowered67C10 is offline   Reply With Quote
Thread Tools
Display Modes
