Old 11-05-2013, 10:36 PM   #1
bojak
bojak's Avatar
Power mirrors
I was hoping someone could share some close up pictures of the power side mirrors that were offered late in the product line. Hope to get some close up views as well as pics from the inside looking out. In photos I've seen so far I can not get a good feel for how they look or all the relationships at contact points. Thanks if you can help.
bojak is offline   Reply With Quote
Old 11-06-2013, 08:55 AM   #2
RandyP
Getting Old; Going Broke
RandyP's Avatar
Re: Power mirrors
I have a pair of doors I just stripped down that had power mirrors. One of them I have not air hammered open yet to get the backing plate out. You just wanting photos of where they mount or what?
Why is every used 350 sbc out of a corvette?
There's only two things that excite a man, expensive toys and real expensive toys.
VEGETARIAN: That's an old Indian word meaning "I don't hunt so good."
When the going gets tough, switch to power tools.
RandyP is offline   Reply With Quote
Old 11-06-2013, 10:00 AM   #3
rs74
rs74's Avatar
Re: Power mirrors
You can also use the conversion van power mirrors too. Gmachinz has a build thread with them installed on his truck. I have a set on my 84 just not hooked up yet.
Roy
85 Short Bed Silverado- Work in progress. http://67-72chevytrucks.com/vboard/s...d.php?t=564818
1987 R10 shortie
rs74 is offline   Reply With Quote
Old 11-06-2013, 09:44 PM   #4
bojak
bojak's Avatar
Re: Power mirrors
Thanks for the pics. Kind of weird how the overlap up into the window. There is build on here of a cc that had his vent window sheet metaled in and then installed newer tow style mirrors. Out of the 2 I think that looked better. Does anyone have pics of the slide on style like they sell in LMC installed?
Old 11-06-2013, 10:35 PM   #5
83GMCK2500
Re: Power mirrors
If the doors are solid there is no reason to air hammer them open, I pulled the backing plates out of a set of these doors by using a heat gun and a putty knife. Heat door skin up, work putty knife around from inside. Glass was out too...
Devin
1983 GMC High Sierra 2500, 4x4, RC/LB, 400 S.B., SM-465, NP-208, Corporate 10 bolt & 9.5" 14 bolt
1996 GMC Sierra SLE 3500 DRW, 4x4, EC/LB, Vortec 454, NV-4500, BW-4401, AAM 925 & AAM 1050
1997 GMC Sierra SLT 1500 4x4, Z71/F44, EC/SB, Vortec 350
My Introduction with my '83s History
New Daily, the '96
83GMCK2500 is offline   Reply With Quote
Old 11-07-2013, 01:45 AM   #6
jitteryguy
GoatLube Experss
jitteryguy's Avatar
Re: Power mirrors
that's what I have on mine, I don't care for the factory power mirror's unless ya mount em in front of the vent window.
Goat Lube Express, locations in Qalat,Afghanistan & Clarksville, Tn.
'87 R30 dually 454/TH400
'85 1/2 ton CCSB
'92 S10 350/350
'84 MonteCarlo 383/PG/9"ford
'78 Malibu wagon 350/350
'78 Cutlass (project family car)
'96 S10 Jimmy (Moma's)
jitteryguy is offline   Reply With Quote
Old 11-07-2013, 08:54 AM   #7
RandyP
RandyP's Avatar
Re: Power mirrors
The doors are junk. You know how much easier it is to remove the regulator with motors attached through a big hole you make? Then it is a 5 second job with the torch to heat up the plates after you drilled the rivets. Trust me, 30 seconds of air hammer makes it easier.
Old 11-07-2013, 09:48 AM   #8
motornut
78K & 79C Jimmys
motornut's Avatar
Re: Power mirrors
burb ones i saw in the wrecker
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-07-2013, 10:23 PM   #9
bojak
bojak's Avatar
Re: Power mirrors
Thanks for that last picture, the one from inside. That answered what I could not make cents of. They don't make cents. They just come up on the window for no apparent reason.
Old 11-08-2013, 09:35 AM   #10
Keith Seymore
Keith Seymore's Avatar
Re: Power mirrors
It's because we used the GMT400 style mirror and adapted it onto the C/K/R/V bodystyle, rather than designing a new mirror for the remainder of the production run.
It doesn't make sense; it looks stupid and I can't believe we actually did it.
It's just shows you where management's head was at at the time.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 11-08-2013, 09:07 PM   #11
Oldriginal86
Re: Power mirrors
Even the switch and it's location is ugly and doesn't match the window/lock switches. One option I'm glad my truck doesn't have.
Oldriginal86 is offline   Reply With Quote
Old 11-08-2013, 11:14 PM   #12
nekkidhillbilly
Re: Power mirrors
if you use dodge ram van mirrors there power and look like the non power chrome mirrors
nekkidhillbilly is offline   Reply With Quote
Old 11-08-2013, 11:16 PM   #13
nekkidhillbilly
Re: Power mirrors
they came in power
Old 11-09-2013, 12:08 AM   #14
joe231
joe231's Avatar
Re: Power mirrors
Do you know the year range?
CHEVY ONLY
Old 11-09-2013, 12:14 AM   #15
franken
Re: Power mirrors
Creek. I'm trying to make vehicles more manual. You're going the other way
franken is offline   Reply With Quote
Old 11-09-2013, 11:09 AM   #16
nekkidhillbilly
Re: Power mirrors
around 94 or so you would have to mod the base im sure to fit to the square door or use the base off the squares oem mirror. be a little fab not alot. if you wanted big tow mirrors like on new trucks you should look at motorhome mirrors though.
either looks tons better than the oem ones or welding up the vent window.
Old 11-09-2013, 11:11 AM   #17
nekkidhillbilly
Re: Power mirrors
the ram van mirrors you could get them in chrome also.
Thread Tools
Display Modes
