Old 11-06-2013, 02:51 AM   #1
tgfeller
Where to find Pitman arms?
I'm rebuilding my front end and the only thing I'm missing out on is a new Pitman arm. Mine's sloppy and needing retirement, but boy, a new one for my build is almost impossible to find!
72 K20, with a 77' K20 Dana 44 front end, however my research shows no difference for the pitman arm between the years 67-87. Any help locating NOS or aftermarket arm would be very much appreciated!
tgfeller is offline   Reply With Quote
Old 11-06-2013, 06:29 AM   #2
Re: Where to find Pitman arms?
I haven't bought one since GM still had them and never had a problem finding a good used ones,so I didn't realize these weren't commonly available. Of all the GM 4wds I've had I've only had one worn at the sector shaft end. I guess you could post a WTB in the parts board if no one else knows a source. I just checked NAPA and they don't list it.
Old 11-06-2013, 08:07 AM   #3
MARKDTN
Did you try NAPA or CarQuest? I would think this is still available, it was a few years ago.
'83 K20-TPI
'73 C10
'79 C10-ex-diesel(SOLD)
'07 Tahoe(Son driving)
'14 Suburban-DD
'71 C10-current project
MARKDTN is offline   Reply With Quote
Old 11-06-2013, 09:19 AM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
I got a new one from Advance about 3 years agoo.It was for a c10 so there may be fewer 4X4 ones available.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-06-2013, 09:28 AM   #5
cdowns
cdowns's Avatar
i just googeled "pitman arm 1972 K20"(30 seconds to do)
got a result with a bit over 100,000 hits???where exactly have u been lookin???
Old 11-06-2013, 11:57 AM   #6
tgfeller
I've definitely done that, if I go the next step clicking on them (10 seconds to do) they only show tie rod ends that attach to the pitman arm and 2wd arms. NAPA didnt have it when I called and assumed Oreillys etc wouldnt have it if they didnt, but ill check.
I'm usually great about finding stuff google/ebay/local but this time the 4x4 arm just sees almost impossible as posting is my last resort in these cases
Old 11-06-2013, 12:16 PM   #7
leftybass209
leftybass209's Avatar
Google is a keyword search that will find any and all words you type in any order, not necessarily together. In order to aid the search you'd have to use quotations. That let's you search the phrase specifically. I'd say check the parts boards here and put up a WTB.
leftybass209 is offline   Reply With Quote
Old 11-06-2013, 03:34 PM   #8
1972SUPERSB
1972SUPERSB's Avatar
I rebuilt my front end and bought an Ac Delco pitman arm. I can get part number if you need it. Sorry looks like you need a 4 wheel drive one
Jeff
1972 Cheyenne Super SWB 350, Auto, Bucket Seats w/Console, Tach, Factory A/C, P/S ,P/B, Tilt
1998 Chevy 1500 Ext Cab 5.7, Pewter w/blue interior
1972SUPERSB is offline   Reply With Quote
Old 11-06-2013, 03:55 PM   #9
MARKDTN
http://www.classicparts.com/1970-91-...ctinfo/76-716/
'83 K20-TPI
'73 C10
'14 Suburban-DD
Old 11-06-2013, 04:04 PM   #10
tgfeller
Wow spendy!
Old 11-06-2013, 06:35 PM   #11
kwmech
Maybe I should have held on to the 1/2 dozen I just scrapped out last week
Old 11-06-2013, 07:19 PM   #12
Lifetime Project 72
Rockauto has them for about 30 bucks...
Chris
Lifetime Project 72 is offline   Reply With Quote
Old 11-06-2013, 07:27 PM   #13
tgfeller
Chris
Not the 4x4 version
Old 11-06-2013, 08:45 PM   #14
Classic-Steele
Classic-Steele's Avatar
I checked the availability on them at work this afternoon and it their discontinued at NAPA too.
Classic-Steele is offline   Reply With Quote
Old 11-06-2013, 10:16 PM   #15
LONGHAIR
It's not exactly a "wear" item, why would you need to replace it?
You can review the site's rules here.
Originally Posted by Longhorn Man View Post
As for reading directions...
The directions are nothing but another man's opinion.
Learn from the mistakes of others, you won't live long enough to make them all yourself...
Bad planning on your part does not necessarily constitute an instant emergency on my part....
The great thing about being a pessimist is that you are either pleasantly surprised or right.
LONGHAIR is offline   Reply With Quote
Old 11-06-2013, 10:24 PM   #16
tgfeller
Slop, damaged thread
Old 11-07-2013, 08:08 AM   #17
Yeah,like I said before,I've had only one needing replacement out of the several GM 4wds I've had. This is on the '72 GMC in my sig. I rebuilt the front end and the truck would still "dart". Although the steering box had no slop,I decided to replace it. Burt4x4 was generous enough to give me the (low mile rebuilt) one he pulled from his Blazer when he went to crossover steering. Before I put that in I checked one more time with someone at the wheel while I watched and saw the pitman arm to sector shaft play. I just put a used one I had on and called it good. 99%+ of used ones will be good and that's my point,you'll be fine with a used one. As Longhair said,It's not a (common) wear item. I'm sure this is why you're not finding them offered by replacement part companies. I would like to know how Classic can have these and no one else. Could those be N.O.S? Or,did they have some made and trying to keep it exclusive,which would explain why they need so much for them. If they're not,than what would a N.O.S. be worth???
Old 11-12-2013, 12:43 PM   #18
snipescastle2
snipescastle2's Avatar
Talking Re: Where to find Pitman arms?
not to hijack the thread, but I found a similar problem trying to locate a "Drag Link or Center Link for a 71' swb, it's not considered a wear part and thus, been discontinued......just FYI.....
Ben
snipescastle2 is offline   Reply With Quote
Old 11-15-2013, 04:09 PM   #19
luvbowties
luvbowties's Avatar
Question Re: Where to find Pitman arms?
Have u checked into reaming and sleeving it? Even tapered holes can be done simply, with the hardest part the finding of a tapered reamer to borrow. Sleeves--even tapered ones--can be made cost-free using auto body sheet metal. *I've read about it, yet never done it myself; but if I were in your place, I'd be doing it in a heartbeat! Holes and shanks can be done!!!
Sam
luvbowties is offline   Reply With Quote
Old 11-15-2013, 10:41 PM   #20
425HP409
425hp409
425HP409's Avatar
Originally Posted by MARKDTN View Post
This is the only one that I could find also and as it is not normally a wear part, most manufacturers do not supply it.
Charles
68 SWB, Dad bought new, now 396 & factory ac
64 Impala SS, 409 425HP, 4 speed AC
64 Bel Air Wagon, 400 Small Block
57 Bel Air all original 283 w/Factory Air
77 GMC Sprint, 454/425HP
67 Olds 442, all original
90 ZR1 Corvette
425HP409 is offline   Reply With Quote
Thread Tools
Display Modes
