Old 11-06-2013, 08:27 AM   #1
jlampka
1971 Radiator Fan Shroud
Anyone know the differenece between an AC and a non AC fan shroud?
I am considering buying a fan shroud for my AC 1971 C20. Thanks!
jlampka is offline   Reply With Quote
Old 11-06-2013, 09:31 AM   #2
WIDESIDE72
WIDESIDE72's Avatar
Re: 1971 Radiator Fan Shroud
The ac shroud is not as deep. I am running vintage air with a non ac shroud though. Your fan clutch or spacer needs to match as well so its the proper distance i tothe shroud for cooling (about half in).
WIDESIDE72 is offline   Reply With Quote
Old 11-06-2013, 01:18 PM   #3
FirstOwner69
FirstOwner69's Avatar
Using the info in the thread link below, it's easy to modify a non-A/C shroud for to be identical to an A/C shroud. I placed masking tape around the circumference with one edge where the edge of the A/C shroud would be and used a sabre saw to slowly cut along the tape. I then sanded the edge smooth.
http://67-72chevytrucks.com/vboard/s...d.php?t=446805
FirstOwner69 is offline   Reply With Quote
Thread Tools
Display Modes
