11-06-2013, 11:09 AM | #1 |
what size mickey thompson wheels? 15x10, 16x10 or 17x9?
not sure what size to go with any pos and negs to either?
truck is an 87 with 4" lift 35's. if i go with 16s or 17s i can use 315/75 instead of 35x12.50 i'm told these run a little smaller and would rub less on the trails than your normal 35x12.50s. any op's? |
11-06-2013, 08:10 PM | #2 |
Re: what size mickey thompson wheels? 15x10, 16x10 or 17x9?
anyone?
11-06-2013, 08:17 PM | #3 |
More info!
Got a lift or is it stock. What's on it now? How wide of rim you want? |
11-06-2013, 08:27 PM | #4 |
don't own mickey thompson wheels, but if you go off-road & air down, 15's have the best lip to hold the bead.
had 15x8 ralleys with 35x12.50/15 on a 4" lifted blazer with no problems. 15x10's, you might rub, or trim your fenders. have a set of 16x10's & a set of 16.5x10's for my crew. better weight capacity tires then 15's, but when you go with big tires (36"-37" up), the selection is not there like the 15's & 17"s. have no real exp. with 17's, other then the toyo's on the wife's suv |
11-06-2013, 09:52 PM | #5 |
11-07-2013, 12:19 AM | #6 |
thanks guys! going with wither 15x10 or 17x9's then. Out of those two for a 87 silver ado with a 4" lift and going with 315/75 or 35x12.50 which should i get and why? anything else to note? I'm just scared the 15" wheels will look stupid with a big 35" tire.
11-07-2013, 12:55 AM | #7 |
Some of the tire shops have a monitor were you select your truck and its color then pick the rim and tire combination and you get a picture of what it looks like.
Mickey Thompson used to sell a really really wide 15 inch tire and it was the best looking thing I have ever seen but they no longer make it. I was going to go with a show polished 15x12 slot mag on a 74 stepside and a 33x13.5 Baja Claw bias ply.The bias ply tires wear out 3 times quicker but they look awesome. This is my 90 gmc without a lift and 31 inch Mickey Thompsons on 10 inch centerlines. |
11-07-2013, 01:29 AM | #8 | |
35x12.50/15's on my k5 38.5's & 40's on 16's. you need that massive rubber look on a 4x4. 18's & up look "dainty" on squares use this to help compare sizes http://www.tacomaworld.com/forum/tir...5r15-315-75r15 |
11-07-2013, 01:43 AM | #9 |
I'm with diesel on this,18s & up do look dainty on a square!! Been running 15x10s on 35s for quite a few years now & they really fit these old trucks for looks.I like them on a practical level too,lots of sidewall when you get into a rutted up lease road.Dont have to worry about wrecking an expensive 18 or 20" rim this way either!!
1977 Chev C30 454/465/14ff DRW 1974 Chev C20.350/465/14ff " Rock n Roll ain't noise pollution" |
11-07-2013, 07:25 AM | #10 |
ok you've made my mind up going with 15x10 mickey thompson classic II's who has the best prices?
11-07-2013, 11:38 AM | #11 |
https://www.google.com/search?q=mick...icial&tbm=shop
Remember you'll need 6x5.5 x 139.7 bolt pattern if its a half ton truck and keep an eye on shipping charges.Some will give you a lower price and whack you on the shipping while others give you free shipping. About $510 from RaceMart Last edited by LynnJr; 11-07-2013 at 11:53 AM. |
11-07-2013, 11:44 AM | #12 |
I got the knockoff of classic II on my 85. Summit 068 series
15x10 with a 35x12.50 |
11-07-2013, 12:03 PM | #13 |
Here is a truck I had with a 6" lift and 35x12.50x15 on 10" wheels.
11-07-2013, 12:55 PM | #14 |
here is my 85 with 4" lift with 35's on 15x10 wheels I am also running a 1.5" spacer on the rear to get the front and back to track the same
Thread Tools | |
Display Modes | |
