Old 11-06-2013, 09:50 PM   #1
superwade57
? s on dying dash n door panels and interior interchange
I have an 86 I also have a 78 interior on the shelf. I have a tan dash pad door panels map pockets and lower door carpet all tan all 78. What's the best way to make it a black and is it quality?
Next
My 86 is pl/pw if I take the manual regulators and door handles from a 78 will that all bolt right into my 86 doors?
Last
I know the 78 dash pad doesn't have a provision for the vin tag and the dash bezel needs to be changed but will the 78 dash slide right in my 86 steel dash and fit properly?
Thanks in advance!
superwade57 is offline   Reply With Quote
Old 11-07-2013, 08:34 AM   #2
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
Re: ? s on dying dash n door panels and interior interchange
Sem makes the best rattle can paints, they also sell adhesion promoters, I bought mine at a local automotive paint supply store.
http://www.semproducts.com/
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 11-07-2013, 12:32 PM   #3
Jonboy
Slots go on anything!
The '78 interior will fit in your '86. You will want to grab the door and window handles from the '78, as they are a bit different. They may function, but will look funny. The '78 door regulator will bolt right in your '86.
The dash pad will work, but the Bezel will not. The headlamp switch moved up when the wiper switch went to the column, and the bezel is too thick at the top to fit on the pad.
1974 Jimmy- 5.3/4L80e/NP241
Old 11-08-2013, 09:30 PM   #4
superwade57
Thanks jeff and jon...a wealth of knowledge as usual. I was almost certain I could do the doors I've got this stuff for sale on the parts board but must be too high even though its all mint and includes shipping but maybe ill just use it. How goofy do you think the 78 door panels would look with an 86 dash?
How would I die the lower door panel carpet and map pockets?
Old 11-08-2013, 10:26 PM   #5
motornut
78K & 79C Jimmys
motornut's Avatar
the older lock rods (78)use metal clips
newer use (87/89) plastic bits
here I used my blue 78 pad with 87/89 panels and parts and pulls, in 78 doors
now i use the 89 pad in there
i think the 78 pad has a clip to remove to fit over the vin,and mine had no speaker holes
John
1978 GMCJimmy4X4-350/203
1979 GMCJimmy4X2-305/350
motornut is offline   Reply With Quote
Old 11-08-2013, 10:34 PM   #6
motornut
78K & 79C Jimmys
motornut's Avatar
and in tan,tried my 88 pad in my 79,didn't seem that far off in colour match either
John
Old 11-08-2013, 10:35 PM   #7
1774btcrew
1774btcrew's Avatar
It sounds like a lot of work to mess up some nice hard to find parts that really won't look right after all of the work is done. There are a lot of people that would like to have those parts. If you really want to use the parts on your truck I guess the only way I could see it justified is if you were wanting to do an older front clip and make your truck look like an earlier model. If you feel maybe your price is too high put them on Ebay with a reserve you feel is fair to you and let the market determine the value. I sell a ton of parts and while it is nice to sell on here I find that a lot of times to get what you want out of an item Ebay is a necessary evil.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 11-08-2013, 10:38 PM   #8
dieseldawg142
dieseldawg142's Avatar
like TexasJeff said, SEM is quite good. i just did my crew door panels with it (tan to black), was pleased with the results.
map pockets would be a pain to dye. you'd have to un-staple the cardboard backing before dying. i just left mine off 'till i find some black ones
dieseldawg142 is offline   Reply With Quote
Old 11-08-2013, 10:55 PM   #9
superwade57
I may try ebay. I wasn't gonna mess with the dash. The doors would have been easy but look sloppy with the newer dash. And I did do the swap to a 73-4 front clip. Did a 5/7 drop put it on steelies and tossed a t56 in doing my exhuast is the morning! Thanks for the advice 1774 you'd know. Remind me to talk to you about some 77 trim I came across. Thanks for all the input from everyone else. 1774 would you look at my for sale ad and pm me what you think fair market is on that stuff or maybe I could wholesale some of it to you or barter something.
Thread Tools
Display Modes
