Old 11-07-2013, 02:16 AM   #1
62_C20builder
62_C20builder's Avatar
Front Wheel Rear Seal Issues
Hello Chevy Heads-
I have run into a problem, while replacing the front drum breaks I noticed that the reals seal was leaking. I proceeded to take the the hub off a noticed that the ENTIRE hub was full of grease...that probably didn't help the leak. Anyway, I went to Napa to get the part, but they had to order it. When it came in, it looked nothing like the original and looked bigger. I asked the guy to double check it and he said it was the right one. I did not think it would fit and I was right. I tapped it in, with all the parts properly greased, and now the nut will not screw into the point where I could put the cotter pin back in. It appears to be short of the whole by the amount of extra material on the new seal. Does anyone know where I can get seals that fit?
62_C20builder is offline   Reply With Quote
Old 11-07-2013, 02:50 AM   #2
jtrichard
Re: Front Wheel Rear Seal Issues
oreilly has national seals $18 each same number and shape as yours..... it looks like the 20965 is .030 smaller shaft size
jtrichard is offline   Reply With Quote
Old 11-07-2013, 04:03 AM   #3
jtrichard
if you can wait for shipping http://www.ebay.com/itm/1960-1961-19...6b2b10&vxp=mtr $15 for 2 seals
Old 11-07-2013, 06:50 PM   #4
62_C20builder
Thanks for the recommendations!
Thread Tools
Display Modes
