Old 07-12-2003, 10:23 PM   #1
perrosinpata@aol.com
perrosinpata@aol.com's Avatar
c-notch problem !! help!!!
For the past two days i have been trying to install mcgauphys c-notch kit on my suburban.Now i am asking myself if the kit is made for suburbans?THe bolt(top) hole for the rear coil on the passenger side does not align .I cut more than enough out of the frame and even cut off the rubber body bushing.What
am i doing wrong any help or advice mabe pix will be greatly appreciated.
Thank you in advance
perrosinpata@aol.com is offline   Reply With Quote
Old 07-13-2003, 12:53 AM   #2
Slammed67
Progress = 0%
Slammed67's Avatar
I assume the C-notch is the same one Classic Performance Products makes? Some of the bolt holes on mine didn't line up perfectly either. I ended up having to enlarge some of them to get the bolts through. Is is way off, or just slightly? If it's just slightly off, then enlarge the holes on the notch so yon can line it up with the stock holes in the frame.
Jason - '67 GMC swb | '57 Bel-Air 4dr hardtop | '56 210 4dr Wagon | 2000 GMC Sierra
Slammed67 is offline   Reply With Quote
Thread Tools
Display Modes
