Old 11-07-2013, 01:24 PM   #1
NEWFISHER
NEWFISHER's Avatar
Tilt column wiring harness conversion
There has been a lot of talk lately about column swaps and thought I would post an easy solution. 73-79 tilt columns come with a flat harness connector. Our trucks have the half moon style. There is a connector through CPP for $19.95 or get the GM O.E one ACDelco 1894851 for abot $10.00. You will have to wire up your own emergency flasher with either of these. The $35.00 ones come with a pre-wired flasher.
My column came with the body side harness cut back 6 inches which allowed me to add some standard female connectors.
At this point you simply shove the color coded wire into the corresponding color terminal at the half moon connector. Works like a charm for about $1
Good thread to follow here:
http://www.67-72chevytrucks.com/vboa...d.php?t=541292
NEWFISHER is offline   Reply With Quote
Old 11-07-2013, 03:27 PM   #2
luvbowties
luvbowties's Avatar
Cool Re: Tilt column wiring harness conversion
Nice post, and I love the cost! Should help lots of column-swappers.
Sam
luvbowties is offline   Reply With Quote
Old 11-08-2013, 07:35 AM   #3
Swed
Swed's Avatar
Thanks for posting! Do you know if the wiring is the same on the 60-62 era trucks with same colours?
Johnny G
-----------Vehicles--------------
* Chevrolet C-10 Stepside 1962
* Audi A4 Avant Quattro TDI 2008
* Sachs Compact 50cc 1967
Swed is offline   Reply With Quote
Old 11-08-2013, 09:50 AM   #4
kieth
kieth's Avatar
I am not sure about the exact wires but when using a 1991 suburban wiring harness and connecting it to a 1966 dash the color codes were the same from 1966 to 1991, gm was pretty consistant.....kieth
kieth is offline   Reply With Quote
Old 11-08-2013, 10:36 AM   #5
NEWFISHER
NEWFISHER's Avatar
All the way back to 53 is what I'm finding
Thread Tools
Display Modes
