Old 11-08-2013, 03:14 PM   #1
MYBAD66
MYBAD66's Avatar
auto to manual trans swap
My 66 C20 has an auto trans Th350 I think haven't checked to make sure. But i'd really rather a manual trans just out of preference. I have seen SM465's and I will eventually use her as a tow vehicle for my offroad toys/ parents boats but she will also be my daily driver. Should I go for an SM465? or something more like the TKO500 as I am a definite speed freak haha
94 Chevy K1500 350
66 GMC c2500 305
MYBAD66 is offline   Reply With Quote
Old 11-08-2013, 03:23 PM   #2
MYBAD66
MYBAD66's Avatar
Re: auto to manual trans swap
also just to clarify I have a 305 out of a 74? c10 So I believe they will mate nicely... right?
94 Chevy K1500 350
66 GMC c2500 305
Old 11-08-2013, 04:40 PM   #3
endlessearth
endlessearth's Avatar
FWIW I was seeking to replace my SM420 4-speed with granny and I did a lot of research. I wanted to be able to cruise at 75 (versus 50.) I wanted to have the opportunity to put more horsepower in front of it down the road. I wanted to keep the 4.11 gearing and the 3/4 ton look and feel. I envisioned my truck as a hay hauler (which it does now) with the ability to run a 1/4 mile (not necessarily really quick but respectable enough.) Ultimately I want a stock looking sleeper AZ farm truck. For those reasons I went with the TKO500 with a mid-shift kit and Chip Quinn here in AZ is building a linkage that will allow me to use the same hole in the floor that is occupied now by the SM420.
This:
plus this:
plus this:
equals this:
endlessearth is offline   Reply With Quote
Old 11-08-2013, 04:46 PM   #4
NEWFISHER
NEWFISHER's Avatar
What are your main reasons for switching? MPG- stick a 700r4 in it. Towing-TH400 if the boat is huge, otherwise 700r4 and a big cooler. Daily driver in Vegas and hate pumping a clutch pedal at every red light on the commute back and forth---700r4. Smokey burnouts and doughnuts in the cul-de-sac--700r4 and a line loc.
I suppose I'm biased after growing up with 4sp cars, 4sp trucks, later 5sp trucks and 6 sp cars and now find that an overdriven 4 speed auto is the best of everything. I eventually grew to hate the granny gear 4sp unless I was hunting or bucking hay, but 4 low does nearly the same. I don't weekend drag race and am not concerned with my fastest time at the end of the track being .5 seconds faster than an automatic, but I do like the comfort, mpg, towing ability and one less pedal to whack my fat head on when I'm working under the dash.
If you are stuck on having a 5 speed, then the Tremec is the answer
NEWFISHER is offline   Reply With Quote
Old 11-08-2013, 05:05 PM   #5
MYBAD66
MYBAD66's Avatar
I just have prefrence to manual shift than auto, more comfortable with it. I don't mind speed as i'm young and insurance will go crazy up if I have a speeding ticket already. Though I do enjoy the 76 nova with it's 350 in the driveway. But the reason I thought about going with an SM465 is that I am on a tight budget at the moment and will eventually being used to tow a offroad toy 94 K1500 roll caged out and such.
94 Chevy K1500 350
66 GMC c2500 305
Old 11-08-2013, 08:46 PM   #6
jtrichard
you need a bell housing with ears and the cross member unless they made a rear mount for that trans??? and pedal assembly under the dash..linkage...a drive shaft or make the existing shaft fit and away you go
jtrichard is offline   Reply With Quote
Old 11-08-2013, 10:17 PM   #7
66Submarine
66Submarine's Avatar
Go for it, I like my SM420 in my DD C-30. (Not a fan of automagics myself.) FWIW, I had my truck with 4.10's and a very tired 283 up to about 80MPH before I started thinking about the ultra-loose timing chain and clogged oil passages and let off. It sings a little on the highway when in the hammer lane, but that's not too big a deal IMO. The TH350 you have now will actually be turning a little faster because of converter slip, so if you are OK with it now, you'll be fine.
1965 C30 pickup 350/SM420/4.10's (daily driver) thread
1968 Impala 4 door sedan (future driver project) thread
66Submarine is offline   Reply With Quote
Thread Tools
Display Modes
