Old 11-08-2013, 10:04 PM   #1
jbristo67
resident oilfield trash
jbristo67's Avatar
5.3 motor mount questions
I'm wanting the motor to be in basically the same place the 350 is now that's in there. I'm going to run my 4l60 that came stock to the blazer and I want as little modification from the tranny back as possible. Do you guys know where I could get adapters to be able to still use my clam shell motor mounts
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 11-08-2013, 10:11 PM   #2
custom97
custom97's Avatar
Re: 5.3 motor mount questions
You might look into Dirty Dingo plates. I too am researching for all the parts needed for my possible conversion.
'86 C10 swb 5/5 drop
http://67-72chevytrucks.com/vboard/s...55#post6239155
custom97 is offline   Reply With Quote
Old 11-08-2013, 10:17 PM   #3
jbristo67
jbristo67's Avatar
Thanks man, seems reasonable enough
2011 Nissan Armada
Old 11-09-2013, 05:14 PM   #4
tinydb84
tinydb84's Avatar
You can do the plates but make sure you get the adjustable ones so you can fit the motor and keep the trans in place.
David
Instagram: myfabguy
Old 11-09-2013, 07:21 PM   #5
y5mgisi
Second Chance Program
y5mgisi's Avatar
Yep. Dirty dingo. for adjustability. For $50 less you can get the car shop inc units that will put them in stock location, but then you loose adjustability.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 11-09-2013, 08:03 PM   #6
ofnaman
ofnaman's Avatar
We went with the dirty dingo mounts. Looked at lots of brands before deciding, but liked the adjustability of the dingo mounts. Not exactly sure where the engine will end up, so having some adjustability is nice.
A sweet 2000 Deville.....
ofnaman is offline   Reply With Quote
Old 11-09-2013, 09:03 PM   #7
jbristo67
jbristo67's Avatar
Ok if I use the cheaper mounts will that line up with the transmission
2011 Nissan Armada
Old 11-09-2013, 09:12 PM   #8
y5mgisi
y5mgisi's Avatar
Did for me! These are the ones i used on my 90 suburban. I bolted these on, bolted my original motor mounts to them, and dropped the motor in. I never unbolted the trans except for the bell housing. In other words, the trans never moved from its mount.
http://carshop.carshopinc.com/produc.../98457/CSP2370
Old 11-09-2013, 09:13 PM   #9
y5mgisi
y5mgisi's Avatar
A buddy just did the same with his 91 suburban.
Old 11-09-2013, 09:30 PM   #10
jbristo67
jbristo67's Avatar
What flywheel did you use
2011 Nissan Armada
Old 11-09-2013, 09:33 PM   #11
jbristo67
jbristo67's Avatar
Also it says that's sets the motor back an inch? Is that what it needs to be in the stock position.
2011 Nissan Armada
Old 11-10-2013, 01:01 AM   #12
y5mgisi
y5mgisi's Avatar
Yes.
Thread Tools
Display Modes
