Old 11-24-2013, 05:16 PM   #1
70c10stepside
aftermarket sm420 shifter
Any? Mine has a ton of play
70c10stepside is offline   Reply With Quote
Old 11-24-2013, 06:23 PM   #2
67_C-30
I have a radical idea!
67_C-30's Avatar
Re: aftermarket sm420 shifter
Not that I've ever seen.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 11-25-2013, 08:59 AM   #3
Replace with better parts. These transmissions don't have external shift linkage,which is what I think of when someone says "shifter". Your shifter is your transmission with a lever out of the top. Don't know if parts are available,but plenty of used transmissions you could rib the parts from.
Old 11-25-2013, 01:38 PM   #4
ksshane
ksshane's Avatar
Novak sells a straight shaft that you can bend to fit you needs
http://www.novak-adapt.com/catalog/t...m420_parts.htm
71 swb 350/4sp manual 5/7 static drop
ksshane is offline   Reply With Quote
Old 11-25-2013, 01:44 PM   #5
zeldman
zeldman's Avatar
Just weld and grind the end of the shifter to fit, and replace the pin that holds the stick in place.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 11-25-2013, 07:52 PM   #6
gvw5400
gvw5400's Avatar
X2 replace the two roll pins on the sides of the shift tower. You may have to weld and grind to fit the slots that the roll pins ride in. Most of the time the end of the shift stick is ok, but it may need a little weld and grind to fit tighter into the shift rails. SM 420 don't generally have the rubber O-rings that isolate vibration from the shifter stick like latter SM 465 transmission do. All the best, Dirk
gvw5400 is offline   Reply With Quote
Thread Tools
Display Modes
