11-25-2013, 05:35 PM | #1 |
Cut off tool stalls under load
I know that you get what you pay for but I was not aware of how it stalls under load. Its a Harbor Freight cheapie http://www.harborfreight.com/3-inch-...ter-47077.html.
I'm running it on a 5HP 80 gallon air compressor at 90psi. Am I not operating the tool right or is there a better tool someone could recommend that wont cost a bunch that will not stall? Took me 20 minutes to cut a 3ft long cut on a 18 GA door panel. |
11-25-2013, 07:46 PM | #2 |
Re: Cut off tool stalls under load
Oil the tool? Running cutting wheel to deep? Thickness of the wheel/cut?
Longer cuts, I usually go electric grinder with a cut-off wheel.
'86 C-30 dually, 454/tbh400 '73 K-20 350/350/205 (sold ) I'm kinda like duct tape- no real purpose, but handy to have around. |
11-25-2013, 07:55 PM | #3 |
a light touch and tryin to cut a little at a time
11-25-2013, 08:47 PM | #4 |
the hf cut off tool is just not a powerhouse. i have one its only good for making small cuts.
i love it though for grinding small welds.
81 camaro 355 4/spd 342 posi my first love. 67 swb step 454/4spd ott 373 posi 4/7 drop. 2000 s10 zr2 little blue truck that never gets stuck. '74 heald super bronc vt8. tecumseh powered moon rover. |
11-25-2013, 09:12 PM | #5 |
combination operator error cheap product
Ed will be known as the Tiger Woods of the integration business |
11-25-2013, 10:55 PM | #6 |
I did get an angle grinder the same day at HF.
http://www.harborfreight.com/heavy-d...der-91223.html I'll look for cutting wheels that will fit and try that instead on the longer cuts. I was letting the wheel run deep vs skimming the top. On the oil I used some 3-1 oil at the time but have seen that Marvel has Air Tool Oil and I'll pick up one of those. |
11-26-2013, 03:23 PM | #7 |
i have only been able to make 8foot long cuts thru 16gauge steel and 4feet long thru 1/4" mild steel anything more wood b pressing your luck
11-26-2013, 05:04 PM | #8 |
blood type; Retumbo
my snap-on guy sells wheels that make a ton of difference. My reversible Matco cut-off tool works so much faster now and with less effort. The wheels are thinner but stronger.
Man rule #77...if you own a 67 stepside with a caddy 472 you will never be in danger of loosing you man card |
11-26-2013, 07:48 PM | #9 | |
nice,you did good
11-27-2013, 10:42 PM | #10 |
Up your regulated pressure. Any shop I have every been in has the compressor shutoff at somewhere around 150psi without a regulator. If your cutting it back to 90psi most of your tools aren't going to like it much. Im sure Im about to catch hell but uncork the compressor and all your tools will run better. I have the exact same cutoff wheel and it likely has been run for over 40 hours total. I have had it a couple years and one full year was in a hot rod/fab shop. The most important thing I can tell you is DONT use cheap cutoff wheels. They will birdsmouth or fly apart and its hurts like hell.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member. |
11-29-2013, 09:56 PM | #11 |
I bought the same cut off tool years ago. It didn't take long to buy a better one. These just don't have any power.
Turp Mcspray New life for an old 2wd, farm blazer http://67-72chevytrucks.com/vboard/s...d.php?t=505987 My Blazer build http://67-72chevytrucks.com/vboard/s...d.php?t=342299 |
12-03-2013, 12:43 AM | #12 | |
hf grinders are cheap enough that i have 3 for flap wheel, grinding wheel and cut off wheels. pull them out of the box, throw away the guard and put a 6 inch cut off wheel on that bad boy.
cool, an ogre smiley Ogre's 58 Truk build how to put your truck year and build thread into your signature shop air compressor timer |
12-03-2013, 11:54 PM | #13 |
shoot i have one of those i bought form hf 6 years ago never had an issuse nbut i bought some new cut off disc from my matco dealer that last alot longer . i oil mine everytime i use it but then again i run my off a 5hp 80gallon compressor thats also as an0other 80- gallon storage tank on it at 175 psi and i use it at work all the time
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
12-04-2013, 05:53 PM | #14 |
Hand Crafted C-10
Yup. Like the guys suggest; jack up the air pressure
and go with a quality wheel.
. Forum Guidelines and Rules
Buying and Selling Code of Conduct Become a Board Supporter! Truck FAQ Ellen... the boards artsy-fartsy, eclectic, truck-lovin' gal-member... |
Thread Tools | |
Display Modes | |
