Old 11-25-2013, 11:31 PM   #1
LSUMurse
LSUMurse's Avatar
Time it takes to swap a crate engine
I'm going to swap in a GM 350 crate into my '68. She currently has a 307 with a Powerglide, P/S (I put in), P/B (I put in), no A/C.
I'm thinking it should be a pretty simple yank and drop.
About how much time should I plan for this adventure?
It's not that I am apathetic, I just don't care.
If your life is a joke, it appears death will be your punchline.
LSUMurse is offline   Reply With Quote
Old 11-25-2013, 11:37 PM   #2
heathbirkendahl
Re: Time it takes to swap a crate engine
Thats a good question. Took 8 hours to get mine out and new one in. Over a couple days. But it some paint touch up.
1971 C/10 - Orange & White
2009 GMC 1500 - Lowered 3/4 22' KMC Slides
heathbirkendahl is offline   Reply With Quote
Old 11-26-2013, 12:00 AM   #3
zeldman
zeldman's Avatar
Plan 2 days and dont get in a hurry, take your time and do it right.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 11-26-2013, 01:24 AM   #4
Lattimer
Lattimer's Avatar
Weekend job with a helper.
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 11-26-2013, 03:01 AM   #5
litew8
litew8's Avatar
A day (10 hrs) with 2 people. Less if using air tools.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 11-26-2013, 05:06 AM   #6
NC_John
NC_John's Avatar
Completely depends on the condition of your truck (what state of restoration) and what else you end up doing while you are in there. Cleaning, servicing/rebuilding/painting other components, etc. You changing out the engine mounts? Transmission mounts? Prepare for "scope-creep." My engine freshening was supposed to take 3-4 days. I'm looking at 3-4 weeks now with all the stuff I added to the job.
If you busted your @ss and only did the R&R of the engine, one very long day is possible.
1970 C-10 LWB "Blu"
Instagram (current build pictures) 70_nc_c10
NC_John is offline   Reply With Quote
Old 11-26-2013, 09:49 AM   #7
TinTop
I just did a BB to SB crate motor swap last weekend. I got the motor out and in in 10 hrs. The next two days were taken dealing with accessory instal. I have air on mine. Do your homework and get all the little things together (mounts, pulleys,hoses set before, and it will go smooth as gravel
TinTop is offline   Reply With Quote
Old 11-26-2013, 10:48 AM   #8
bbcmudtruck
Is your crate engine complete and ready to drop in? Or do you need to add all the accessories and such? The questions asked above are going to completely dictate how long it takes. If you are simply going to swap motors, and your new motor is completely ready to go, 6 hours or less. If your going to paint, clean up grease, oil, dirt etc, I'd plan on two 8 hour days. If you have the correct tools, it really doesn't take that much time. About three or four weeks ago I pulled my motor, cleaned up entire engine bay with degreaser and power washed it. Waited for it to dry, painted everything inside the engine bay and waited for it to dry. I had to replace a bunch of missing bolts from the previous owner doing a half-assed job as well. While I had the motor out, I dropped the pan, pulled the main and rod caps to check bearings, swapped out intakes and painted the engine. With all of that, I had the job completed in a long 12 hour day/night. Now filling all the fluids back up, rerouting some wiring to clean up the p/o hack job and also putting in new motor mounts it took me another 4 or 5 hours to the point where I could fire off the motor and check for leaks. So long story short, if you have more work to do other than just simply swapping motors, I'd plan on a full saturday and sunday, provided you have all parts on hand. If you simply have to swap motors, that can be done inside of an easy day, if your familiar with doing it.
bbcmudtruck is offline   Reply With Quote
Old 11-26-2013, 10:56 AM   #9
Billett
Billett's Avatar
I think it depends on the condition of the rest of the truck not just the engine. Once you have the old one out you'll notice a lot of things that could stand to be done and when the engine is out is the easiest time to do them...
We're in the middle of a buick swap that's pretty straightforward, but noticed things like hoses that could be replaced, shocks, painted brackets, etc. Then you have to wait on parts...
Will
1968 C10 - Project Texa Go 6.0/4L80e
2003 Mitsubishi Lancer Evolution
2002 Ford Excursion 7.3L
2024 Toyota Sienna
Billett is offline   Reply With Quote
Old 11-26-2013, 10:56 AM   #10
72bowtiestepper
I'd say 2 days also....plan on making at LEAST one extra trip to the auto parts store after you think you have everything on hand for the swap. A extra set of hands will help too, when dropping in the engine & trans. Don't rush...do it right the first time !
72bowtiestepper is offline   Reply With Quote
Old 11-26-2013, 11:42 AM   #11
Coley
Coley's Avatar
Smile Re: Time it takes to swap a crate engine
I'm definitely in agreement with the 2 day 'window' for replacing the motor.
The last time I did this was on a weekend...no problems.
I started on the friday night just as a light duty warm-up....stuff like the battery out, drained the coolant, a few other simple things including starting on (and testing for) a few possibly tough bolts on the exhaust etc. This is maybe a good time to hit a few tough bolts with some liquid wrench overnight...just to make saturday easier.
Made for a fun, easy interesting friday evening, nothing too serious or stressful and I was that much more excited on Saturday to get underway.
Sunday was mostly a start-up morning and tune-up day/afternoon....no worries.
Get a buddy who can hang in there tho' and don't forget to take the odd break and keep with a simple plan that works for everyone.
Under good planning and circumstances its a heck of a fun and interesting event in my opinion.
Oh, and don't forget the beer and pizza on Saturday night!!
All Good
Coley
....for some men, there is experience, skill and effort....for the others...there is visa and UPS LOL
1966 Chevy 1/2 ton (Florida- Red/white)
1972 Chevy 1/2 ton (California- Blue/white)
2005 Chevy Silverado HD2500/Duramax
2000 Dodge Ram 1500
Coley is offline   Reply With Quote
Old 11-26-2013, 12:20 PM   #12
67ChevyRedneck
67ChevyRedneck's Avatar
If you know what you're doing, a little paint and clean up, should only take a weekend.
If you're new to all this, not sure how to install an intake, distributor, etc... it may take you a few weekends.
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 11-26-2013, 12:28 PM   #13
GASoline71
"I ain't nobody, dork."
GASoline71's Avatar
Get a couple of buddies to help... get pizza delivered and have some beers on hand. Make it a weekend project.
Gary
'cuz chicks dig scars...
My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread.
The Rebuild of Creeping Death after the wreck
Originally Posted by LONGHAIR View Post
I would never rebuild a 305.
Originally Posted by prostreetC-10 View Post
I love using vacuum gauges as part of the carb tuning process. I hook the gauge to the inside of my garbage can and leave it there.
Originally Posted by Marv D View Post
Remember Murphys 2nd law of mechanical relationships... "OPPOSING COMPONENTS ATTEMPTING TO OCCUPY THE SAME SPACE, AT THE SAME TIME, GENERALLY END UP OCCUPYING ADJOINING SPACE AT THE BOTTOM OF THE OIL PAN"
Originally Posted by cableguy0 View Post
Its cheaper to listen to advice given when you ask for help than it is to ignore everyone and wait for carnage.
GASoline71 is offline   Reply With Quote
Old 11-26-2013, 01:45 PM   #14
TinTop
My Crate was a long block however, it needed a harmonic balancer, intake manifold, new carburetor, exhaust (headers) all the plumbings (air, coolant) change pulleys, change PS pump and all new mounting hardware as the big block accessories did not fit a 350 except for the motor mounts. Go figure... Thanks Chevy
All in all I had most all ready before I started. A long satisfying weekend.
Thread Tools
Display Modes
