Old 11-26-2013, 08:47 PM   #1
jim ellis
jim ellis's Avatar
transmission replacement
If I replace my granny low four speed with a five speed can I use my existing clutch linkage or will I have to convert to hydraulic?
jim ellis is offline   Reply With Quote
Old 11-26-2013, 09:20 PM   #2
Lattimer
Lattimer's Avatar
Re: transmission replacement
You can use the factory linkage with a 5 speed TKO, I did. I think the 6 speed you are forced to do a new bellhousing and hydro clutch
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 11-26-2013, 10:12 PM   #3
hugger6933
you can use the factory linage. I am gonna do a T-5 swap on one of my 70's. Go to the top of the page and click home on the upper left corner of the page. Then click on tech tips, then click on T5 swap I think it is on the 4th page in the tech tip section there is a lot of info even if your not going with a T-5 some good swap stuff as well. Jim
hugger6933 is offline   Reply With Quote
Thread Tools
Display Modes
