Old 11-26-2013, 09:03 PM   #1
Rubble
Steering column from 92 GMC 3500 to a 86K20
Will a steering column from a 1992 GMC 3500 bolt into an 86K20? My 86 doesn't have tilt,this 92 does.Both are standard trans.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 11-26-2013, 09:21 PM   #2
Sodell
Sodell's Avatar
Re: Steering column from 92 GMC 3500 to a 86K20
I don't think it will, and the electronics are different.
Scott
87 Chevy 2WD SWB, 88 4x4 LWB
http://67-72chevytrucks.com/vboard/s...d.php?t=610652
Sodell is offline   Reply With Quote
Old 11-26-2013, 09:36 PM   #3
Rubble
I thought about the wiring after posting it!! It was a long shot eh...thanx
Old 11-27-2013, 01:09 AM   #4
1774btcrew
1774btcrew's Avatar
I think the electrical should be the same. I build a lot of columns and have used the turn signal switches out of the 92 body style trucks. I do know that where it mounts to the floor will be different. I think the 92 has the piece welded to the column where it mounts to the floor. It is possible to cut this off and use the gasket and plate from your 86 column. What would be most important would be to compare the lengths and then decide if it is worth your time to cut the floor plate off the 92 column.
AZPartsLocators on Instagram
1972 Cheyenne Super Short Bed big block "Blackie"
1977 Crew Cab GMC Short bed with 4BT Intercooled Cummins Diesel and a 4L80e "The Junkyard Dog"
1985 Crew Cab Chevy dually with 5.9 Cummins "The Big Dog" This is what my dad liked to be called by the grandkids before he passed so it seems fitting for his old truck.
1774btcrew is offline   Reply With Quote
Old 11-27-2013, 01:37 AM   #5
Rubble
I will have a closer look at column once it gets parted out..
Thread Tools
Display Modes
