Old 11-28-2013, 08:26 PM   #1
MrBlue
MrBlue's Avatar
Cold Ride
Happy Thanksgiving to All,
Anyway, a couple of weeks ago I took the truck to pick up some shelving that the local box store did not have. No big deal, just drive 30-minutes to the store that had stock. Temp outside was 40-ish degrees. Turn on the heater and start driving. After a couple of miles on the highway, and the heater fan on high, it starts to cool off in the truck. Not bad, but as I recall from way back when, that this was not normal. I could feel the heat coming from the vents, NON AC cab.
So, is this normal?
The heater core and fan motor are new. Yes, the hoses are connected correctly.
Thanks for stopping by.
MrBlue
72' C-10 350 TKO-600 Current Project
54' Ford F-100 Life Long Project
MrBlue is offline   Reply With Quote
Old 11-28-2013, 08:45 PM   #2
orangek5
orangek5's Avatar
Re: Cold Ride
coolant level low?
1970 Jimmy 4x4 IL6
1971 Jimmy 4x4 350ci v8
1971 SWB 327ci v8
1972 Short Stepside 305ci v8
1972 Blazer 2WD CST LS9 350ci 4sp
1999 4 Door LB 1 Ton Old Body Style 5.7 v8
orangek5 is offline   Reply With Quote
Old 11-28-2013, 08:56 PM   #3
marvgarr68
marvgarr68's Avatar
Re: Cold Ride
Low coolant will do that also stuck open thermostat. What was the temp on the gauge? What deg thermostat do you have? I know if its a 160 it does not get very warm in the cold.
1976 k20, 350 built, 44/14 axles
1968 c10 6.5 turbo diesel,t5 trans
1977 gmc c3500 dually, crew, 4-53t, 5&3 trans
http://67-72chevytrucks.com/vboard/s...d.php?t=591188
marvgarr68 is offline   Reply With Quote
Old 11-29-2013, 03:27 AM   #4
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Cold Ride
With the engine warmed up and idling, and the heater on, are the radiator hoses hot to the touch? And are the heater hoses hot to the touch? Do you have a good 190* or 195* thermostat?
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Stocker is offline   Reply With Quote
Old 11-29-2013, 10:11 AM   #5
Re: Cold Ride
I always run 180 deg. thermostats and get enough heat that I never use an ice scraper and never where a jacket when driving. I set the levers in the center and don't use the fan. First check coolant level. Usually when that's low you get off & on heat. Next check the the hoses for heat and the upper radiator hose for expansion. If they're not hot check the thermostat. The next thing would be poor flow in radiator and/or heater core. Another possibility would be the levers aren't activating (broken/loose cable or other related problem)
Old 11-29-2013, 10:18 AM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Cold Ride
I haven't looked at the current replacement heater cores.I have a Dodge Dakota and a 2000 Blazer.Both have smaller diameter tubes in the heater cores than was common when these trucks were new.Both have to have the heater core flushed about every 2- years.The coolant's anti leak properties tend to clog these smaller tubes.
I just use a garden hose and flush clear water thru the core each direction a couple times until I get good flow(you can see the difference) then reconnect and the heat comes back.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-29-2013, 10:41 AM   #7
MrBlue
MrBlue's Avatar
Re: Cold Ride
Gents,
Thanks for the responses.
The coolant level is/was fine as is the temperature of the heater hoses.
Coolant temperature was 200-degrees.
I am wondering if the heater fan is pushing enough air? Or that these cabs have no insulation and that is contributing to the coolness of the ride when it is cold outside.
MrBlue
Old 11-29-2013, 11:30 AM   #8
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Cold Ride
I wouldn't think so. These heaters pour out an awful lot of heat and I've never had any problem staying warm inside.
- Mike -
RIP El Jay
Old 11-29-2013, 11:53 AM   #9
Re: Cold Ride
These trucks have always been some of the warmest vehicles I've driven. Definitely something wrong on yours. Either the heater core is restricted or your controls aren't activating what they are supposed to. In other words,your heat isn't being turned on. I only use the fan to defrost/deice before driving or when driving with the window open when it's cold out. Ok,or of I need more defroster. These trucks' heat will have you stripping to naked and sweating with the fan and heat on high for very long. Even if it was the fan,can you hear the fan blow? If you can hear it,it's blowing. I don't know how long you've owned you truck or if it has spent any length of tome sitting,but mice can get in there and block air passages and/or keep flappers open/closed. If you're making good heat and it's being blocked,you could end up with a parts meltdown,or worse,if not remedied
Old 11-29-2013, 01:24 PM   #10
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: Cold Ride
^ Good point, but in his initial post he said the heater core & fan motor are new, so I figured the mice have been removed.
One other thing to check -- is the fresh air vent in the kick panel open? That would let in a lot of cold air....
- Mike -
RIP El Jay
Old 11-29-2013, 07:15 PM   #11
Re: Cold Ride
Oh yeah,I guess the mice could be within the heater itself (under dash) still. I've found them nested where the diverter was stuck shut. If you hear no fan,check the fuse and connections.
Old 11-29-2013, 07:58 PM   #12
bigmac73
bigmac73's Avatar
Re: Cold Ride
i would check the heater resistor, maybe the fan motor is not getting enough juice to turn fast enough??
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 11-29-2013, 08:09 PM   #13
Mister-B
Re: Cold Ride
Yes. Plus with a truck, you're heating up a small enclosed cab. You don't have a back seat and rear cargo area to heat.
Mister-B is offline   Reply With Quote
Old 11-29-2013, 10:21 PM   #14
MashTheGas 72
Re: Cold Ride
I just went through this and found out my flapper in my heater box was stuck. I freed it up and instantly the heat started working and I had to roll the windows down it was so hot. I reached under the dash and worked the flapper Control with my hand until it freed up. Mister-B was the one who told me to try this. Hope this helps.
72 GMC 1/2 Ton
MashTheGas 72 is offline   Reply With Quote
Thread Tools
Display Modes
