Old 12-03-2013, 11:06 PM   #1
landy
Heater/AC Diverter Box and Flap
The flap inside the diverter box no longer moves with the cable. I can push the flap open and closed so I'm assuming the flap is done for after 40 plus years of service ('72 Blazer).
Brothers has replacement boxes listed for around $110 and LMC for around $120. I've been dissatisfied with some of the parts I've purchased from LMC, so am intending to purchase the box from Brothers, especially since it's $10 cheaper. But are there actually multiple manufacturers making these kinds of replacement parts or are these made at the same Chinese factory, but Brothers is just cheaper?
landy is offline   Reply With Quote
Old 12-04-2013, 12:37 AM   #2
zeldman
zeldman's Avatar
Re: Heater/AC Diverter Box and Flap
I would guess there is only one manufacturer remaking these. Are you sure the door is broken? I had one years ago and it was slipping on the steel rod the door is mounted on. A little super glue and aluminum strips re-enforcing the door so it wont break and it worked fine.
2005 GMC K2500HD D/A
1993 GMC K1500
2011 Subaru Legacy.
2013 Subaru Outback
1970 C-10 2WD, SWB stepside, 292, TH350, PS, more rust than anything. God is my pilot.
zeldman is offline   Reply With Quote
Old 12-04-2013, 01:36 AM   #3
landy
I think the door is slipping on the steel rod. I haven't taken it out, but I'm assuming that part of the door is broken or cracked. Perhaps it's repairable per your suggestion. Looks like removing the box is a bit of a PITA. Can the door or flap be removed w/o removing the box?
Old 12-04-2013, 07:42 AM   #4
Andy4639
Old member
Andy4639's Avatar
Wink Re: Heater/AC Diverter Box and Flap
I tried fixing mine several years ago with no success. I bought mine from a vendor locally U have to pull it out to try and fix it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 12-04-2013, 12:07 PM   #5
cdowns
cdowns's Avatar
i never had any luck tryin to rebuild or save the things// and found the easy warmest way to fix was replace with a new one from lmc at the time
Old 12-05-2013, 03:58 PM   #6
BigRed76
BigRed76's Avatar
Maybe check Classic Heartbeat or GMC Pauls? They both have really good parts for our trucks...
Zach
1970 Chevrolet Custom Camper K20
1971 GMC Super K2500, 12V/NV4500 swap in progress
1971 Chevrolet Custom C10
1972 Chevrolet Custom Deluxe C20, 5.3/4L60E
1972 Oldsmobile Cutlass Supreme, 455/TH400, 3.73 posi
2004 GMC Sierra 2500HD, LB7/Allison, CCSB
2005 GMC Sierra 1500, 5.3/4L60E, CCSB
BigRed76 is offline   Reply With Quote
Thread Tools
Display Modes
