12-17-2013, 12:57 AM | #1 |
Ammeter - Shunt question
If I wanted to wire my factory 1972 ammeter, directly to my late model alternator (70 amp), bypassing the factory wiring, what size shunt would I need?
Also, if this is REALLY bad idea, please advise. Thanks. |
12-17-2013, 01:07 AM | #2 |
Re: Ammeter - Shunt question
I would get a shunt that would with stand 70 amps. I could be off base with this... other opinions?
A husband can be right...or...A husband can be happy. 67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk. 1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc JOHN 17:3...The better side of "LIFE" Remember: Everyday is a good day...Some are just gooder! |
12-17-2013, 10:22 AM | #3 |
I assume you talking about the fused 16-18 gauge wire that comes out of the firewall connector, and instead of unwrapping the harness near the voltage regulator to connect the wire to the 12 gauge red wire three-way or whatever connector there, you want to connect it to the 12 gauge red wire (that runs from that same three way connector) at the alternator?
12-17-2013, 12:08 PM | #4 |
I agree on the 70 amp capacity of the shunt, but I believe the other factor is the milli-volt capacity of the ammeter. Does anyone know this number for a factory 1972 ammeter?
12-17-2013, 02:25 PM | #5 |
I don't know the number but the factory ammeter is protected by two 4 amp fuses. It reads the amps by reading the resistance between the two connections, (approximately 3' of #10 wire).
Jim
1971 Shortbox step side 4x4, 350 sbc, 3:07 rear end 1965 Impala SS 400 sbc, Muncie rock crusher 1966 Impala SS 396 bbc, TH 400 1969 El Camino, 350 sbc, TH 350 1971 Snowplow built on a Blazer frame 1972 GMC Short bed, stepside, TH 400, 427 BBC |
12-17-2013, 03:02 PM | #6 |
Hmmm...build a shunt with 3' of 10 awg wire and a couple of fuses...wonder if it would work...
12-17-2013, 03:14 PM | #7 |
member #16
Will a factory ammeter handle full system amperage?" I don't know, But there must be a reason they used the low amp shunt.
john http://67-72chevytrucks.com/vboard/showgroups.php board vendors http://www.flickr.com/photos/1745471...7602865984234/ |
12-17-2013, 03:26 PM | #8 |
There is no way the shunt they have with 4 amp fuses in it carries full system current. Could it be a shunt of a shunt? Could it carry just 1/25 of the current and be part of a 100 amp shunt? I don't have a wiring diagram to look at that includes the shunt circuit.
When a fuse blows, the gauge quits but you don't quit charging. Just pushing this to the top so smarter than I will chime in.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
12-17-2013, 05:21 PM | #9 | |||||
Msgt USAF Ret
The shunt isn't low amp as described above. Here's a picture of the three way connection in the factory wiring in real time. This would be the best place to wire the ammeter feed wire because one of the wires is connected to the external regulator which is the red sensing wire for the alternator to help with remote voltage sensing.
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
12-17-2013, 05:39 PM | #10 |
Old member
I have to ask why?
Why do U want to run it straight to the alternator. I also would suggesting put a volt-meter gauge in the truck.
12-18-2013, 03:25 AM | #11 |
I appreciate all the good information.
Shunts can be purchased from an electronics store. Question is: how many millivolts is the factory ammeter rated at? If anyone has this piece of info, it would be greatly appreciated. The reason for wiring up my own is that the PO swapped in a GM crate motor and the factory wiring is trashed. I'm just trying to get all the gauges working. |
12-18-2013, 07:48 AM | #12 | |
Old member
I would still install a volt reading gauge.
12-18-2013, 10:51 AM | #13 | |
Msgt USAF Ret
I have covered this subject so many times I know it by heart. If you check the electrical section you can find all the info you need. Most of the threads on dash light to gauge conversions will cover it. Here's one of the threads......http://67-72chevytrucks.com/vboard/s...d.php?t=581719 Here's a picture showing the fusible link and the shunt with the ammeter wires and fuses. The ammeter wires go through the firewall block to the dash cluster plug on terminals 1 and 12 and then to the ammeter via the copper strips. Here is the dash cluster diagram. Note terminals 1 and 12. Here's one with the internally regulated alternator conversion with the ammeter wires.
12-18-2013, 12:23 PM | #14 |
VetteVet, I appreciate your vast knowledge, and especially that you are willing to share it. I am sure that you have forgetten more than I will ever know.
It matters because I think it may be better to simply wire-in a self contained shunt (if possible), rather then tap into a suspect wiring harness. By the way, is that 1.5 volts or 1.5 millivolts? Thank you again for all the info. |
12-18-2013, 02:48 PM | #15 | |
Msgt USAF Ret
.........http://www.bracketracer.com/nova/shunt/shunt.htm
12-18-2013, 04:03 PM | #16 | |
It's 1.5 Volts. I just tested a few spare factory ammeters I had laying around to be sure. They varied a little bit but 1.5V gave pretty close to a full scale reading on them. Like JimKshortstep4x4 said earlier, the factory ammeters are protected by 4 Amp fuses. Out of curiosity, I used my multimeter to measure the current flowing through the meters I was testing. They all had close to 2 Amps going through them at full scale deflection. That's the current that's flowing through the factory ammeter itself ... not the shunt. |
12-20-2013, 01:29 PM | #17 | |
So I did a bit more testing with a power supply and a rheostat to vary the current and voltage to the factory ammeter being tested. Full scale was at about 1.8 Amps through the meter. And that resulted in about 180 milliVolts across the ammeter's terminals. I don't have a micro-ohmmeter to measure it directly, but using Ohm's Law, that works out to about 0.1 Ohms for the factory ammeter's internal coil. |
12-20-2013, 07:33 PM | #18 |
Ray, thank you for the further investigation. From what you have learned would you agree that a shunt with a rating of 70 amps and 180 millivolts would work in this application?
Also, assuming those exact values are not available, how close does the shunt need to be, would a 100 amp, 200 millivolt shunt work? |
12-20-2013, 10:19 PM | #19 | ||
You're welcome!
I say in theory because I believe most commercially available ammeter shunt ratings are calculated for use with a high impedance meter movement. As I posted above, the coil inside the factory ammeter is only about 0.1 Ohms. That will allow a considerably higher amount of current to flow through the meter itself than what you'd get with a high impedance movement. Quote:
A 100A, 200mV shunt will have a little lower resistance (as compared to a 70A, 180mV shunt) so I'd expect that to give a slightly lower reading on the ammeter for the same current. But again, those shunt ratings are most likely calculated for use with a high impedance meter, not the 0.1 Ohm factory ammeter so that's going to change the calculations. |
Thread Tools | |
Display Modes | |
