12-20-2013, 02:09 PM | #1 |
Door Seal Installation
This weekend I plan on installing some rubber door seals on my 84'. Is there any adhesive I am suppose to use for the installation?
http://67-72chevytrucks.com/vboard/s...d.php?t=580955 http://youtu.be/JYoQJYTXKqI 1984 Chevrolet Scottsdale C10 "Project Platinum C10" 1971 Chevrolet Chevelle "Project Car" |
12-20-2013, 03:22 PM | #2 |
Re: Door Seal Installation
No.
The factory didn't use adhesive but did crimp the edge of the seal onto the pinch flange in the door opening using a "scoffing" tool (...Lord knows why it is called that). However - after time the seals begin to fall down around the tight bends of the upper corners. If you leave the seal a little long and really press it into those tight radii you will probably be all right. Mine were done five years ago and are still holding up ok. Or - if you wanted to use a little urethane windshield adhesive in those corners I don't think anyone would fault you K
Chevrolet Flint Assembly 1979-1986 GM Full Size Truck Engineering 1986 - 2019 Intro from an Old Assembly Guy: http://67-72chevytrucks.com/vboard/s...d.php?t=342926 My Pontiac story: http://forums.maxperformanceinc.com/...d.php?t=560524 Chevelle intro: http://www.superchevy.com/features/s...hevy-chevelle/ |
12-20-2013, 03:53 PM | #3 |
I do not think the seals are installed using any type of adhesive. Here is a series of how to videos I found online.
12-20-2013, 05:07 PM | #4 |
Thanks guys for the help! I'm glad I watched that video because I have to install my door windows and wasn't sure how to do so.
Thread Tools | |
Display Modes | |
