Old 07-17-2003, 12:26 AM   #1
RAT-AT-TACH
RAT-AT-TACH's Avatar
heat isolator?
i just had my burb tuned up yester day ,and she started pinging,i took it back today and the mec put the timing light on it and brought it in a touch,then he tested the temp in my float bowl(edelbrock ps 800) which was at 110-115 he said it should be no more than 85, so im just burning my fuel into vapor at such a high temp,im going to be putting a heat isolator on the carb tomorro to keep it cool then he will be able to tune the timing in better.
does this sound right to anyone?
i should mention the motor is a modified 402 bb .
RAT-AT-TACH is offline   Reply With Quote
Old 07-18-2003, 04:13 AM   #2
jimfulco
If the temp should not be more than 85, then what temp is it when it's 95* outside & the truck has been outside for years but it runs fine?
jimfulco is offline   Reply With Quote
Old 07-18-2003, 11:54 AM   #3
ddsmith
Glowing since 1978
ddsmith's Avatar
I do agree that a hot carb is a bad thing but I don't think those temps make sense. The old vettes had a heat insulator and a sheet metal plate that mounted under the carb to keep radiant heat off the carb float bowls. You could probably fashion a similar heat shield if you felt it would help. It seems to me that the truck would just run a little rich when hot outside or in stop and go traffic. The big thing that I see as a problem is the percolation out the carb vents when you stop the engine after running it on a hot day. The vapor bubbles carry raw gas up and out the vents and into the intake. This in turn create a big PITA for starting and potentially shortens engine life if raw gas washes the cylinder walls down for you.
66 Chevy C30 Stakebody Dump, PS,PB, 327cu in
71 Corvette Coupe 454 4 speed
69 Chevy C20 Custom Camper
ddsmith is offline   Reply With Quote
Old 07-18-2003, 03:55 PM   #4
cdowns
cdowns's Avatar
i think a heat isolator is a good thing to use in fact i'm pretty sure edelbrock reccomens using one why they dont include one with their carbs stumps me
Old 07-18-2003, 04:32 PM   #5
Gotta71C20
I think you should find a new mechanic. The one you have is an idiot. Larry
Gotta71C20 is offline   Reply With Quote
Thread Tools
Display Modes
