2wd vs 4wd ride height
I'm not finding the exact info I'm looking for. What is the difference in ride height between 2wd vs 4wd? The reason I ask is because I am going to lift my 2wd suburban using the 4" lift spindles from an 88-98 c1500 and lower control arms from a 3/4-1 ton 73-87. It has a broken main leaf around one of the bushings, so leaf springs are a must. I don't think I can just buy a 4" lift spring for a 4wd and expect it to sit level. I think it would be to tall in the rear. Since gm didn't use lift blocks in the 4wd, the 4wd springs must have a little more arch. According to LMC none of the part numbers match between 2wd vs 4wd. What my thoughts are is to get a 2.5" lift spring for a 4wd. I'm trying to avoid using a lift block, or at least not much of one.
Re: 2wd vs 4wd ride height
I have 4" lift all the way around n it's pretty level. Not perfect but all wheel wells are within 1.5 inches of another. If the back is too high that's just a reason to lift the front more right?
When in doubt, throttle it out! 1974 Chevrolet Custom K20 2005 Ford Ranger Edge 1985 Chevrolet Custom Deluxe C10 |
The spring hangers account for quite a bit of the ride height difference between a 2wd & 4wd. The 2wd spring hangers tuck the springs up closer to the frame than the 4wd hangers.
No it's a 4x4... And i agree onthe 2wd vs 4x4 hanger... Why not lift the front, notice the differenve in front to back. Then lift back to equal the difference?
#6 | ||
I will look a little closer at the hangers between the two. I was figuring the 4wd springs would have more arch. I don't see any 2wd lift springs for sale. 4wd would be my most practical option. If I lift the front 4" I don't want to buy a 4" lift spring for a 4wd and it actually lift my 2wd 7". If the hangers are the biggest difference, then a 4" spring should set me close. If anybody has any pictures of 1/2 ton 4wd hangers I'd like to see. |
#7 | |
![]() And here's what the ride height with those springs looks like with the bed back on the truck: ![]() |
6>8 Plugless........
![]() Join Date: Sep 2007
Like Ray stated the spring hangers are the biggest difference on a stock height leaf spring set up on these chevy trucks. 2wd hangers are shorter than 4wd ones. You could just do a shackle flip and get your height in the rear and leave your rear springs alone.
Ryan 1972 Chevy Longhorn K30 Cheyenne Super, 359 Inline 6 cylinder, Auto Trans, Tilt, Diesel Tach/Vach, Buckets, Rare Rear 4-link and air ride option Build Thread 1972 GMC Sierra Grande Longhorn 4x4 1972 Chevy Cheyenne Super K20 Long Step side tilt, tach, tow hooks, AC, 350 4 speed 1972 C10 Suburban Custom Deluxe 1969 Chevy milk truck 1971 Camaro RS 5.3 BTR STG3 Cam Super T10 1940 Ford 354 Hemi 46RH Ford 9" on air ride huge project Tired of spark plugs? Check this out. |
#9 | ||
Thread Tools | |
Display Modes | |
