Old 01-08-2014, 08:19 PM   #1
sboris
sboris's Avatar
Column assembly. Bail me out
Ok, feeling kinda stupid here.. Tore this apart over a year ago. This is a 68, 4spd. No linkage. Should be easy right?
I get where the bearing should go, but does the spring really press directly on the bearing? Doesn't seem right..
And what the hell is that big washer? Wheres it go? The hole is too big that I can tell.
Where does the felt go in the tube? Inside the tube? Behind the bearing?
Am I missing parts maybe, I don't think so as I had it all bagged.
Chime in and bail me out. Thanks
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
71 chevy Beauville van
My build.
http://67-72chevytrucks.com/vboard/s...d.php?t=633039
sboris is offline   Reply With Quote
Old 01-08-2014, 08:59 PM   #2
RANDY COX
RANDY COX's Avatar
Re: Column assembly. Bail me out
I've never tore one apart, but judging by the picture looks like that big washer goes on the bottom of bearing then the spring against it, Not sure where that felt goes unless it goes inside of the lower part of column.
Sorry I couldn't be of more help.. Maybe someone else will chime in...
1964 BBC 402 4x4
RANDY COX is offline   Reply With Quote
Old 01-08-2014, 09:03 PM   #3
sboris
sboris's Avatar
Yeah, that's what I thought on the washer. But the spring just falls through it. Hole too big..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 01-08-2014, 09:28 PM   #4
sboris
sboris's Avatar
Just wanted to add, the washer fits the inside diameter of the tube perfectly..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 01-08-2014, 10:13 PM   #5
RANDY COX
RANDY COX's Avatar
I looked at my Haynes manual from 67-87 chevy trucks and it didn't really show any step by step pictures, It just told how to disassemble but no pictures you know what they say a picture is worth a thousand words..it did however say to remove the felt seal from the shifter tube....surely somebody on here knows how it goes together. Wish I could be more help...
1964 BBC 402 4x4
Old 01-08-2014, 10:50 PM   #6
sboris
sboris's Avatar
Thanks Randy.
Your right about pics. I need to find one I can look at..
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 01-09-2014, 01:52 AM   #7
athleo
athleo's Avatar
I just re-did my column on my 71 a while back and if I remember correctly the washer that you show in the phot goes between 12 end 3 on the diagram in your post! On the top end of your column you have a white plastic piece and that washer sits below it to keep iit from being pushed too far down the tube when you tighten the assembly down! The padding goes on the lower end and it just keeps the dirt out of the tube! Let me know if you need any more help with it I wish that I had taken pictures when I had mine tore apart!.....dwt.
1968 K20 custom panel truck!
1971 K20 custom truck!
1990 K3500
2007 K2500 Silverado HD!
athleo is offline   Reply With Quote
Old 01-09-2014, 02:01 AM   #8
athleo
athleo's Avatar
Also the way you have the bearing, spring, and locker in your photo is correct the only thing that you are missing is the heavy duty washer that goes with then its in the diagram in your post! The hole in the washer is the diameter of the shaft and it is twice as thick as the washer in the above picture!......dwt.
1990 K3500
Old 01-09-2014, 08:46 AM   #9
sboris
sboris's Avatar
Thank you! That washer on the upper column makes perfect sense. Must have misplaced the lower one I guess. Will try this tonite!!
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 01-09-2014, 11:53 AM   #10
LockDoc
The Older Generation
LockDoc's Avatar
Shawn,
The column in this thread has the shift levers but it may help you out some...
http://67-72chevytrucks.com/vboard/s...d.php?t=471499
Let me know if you need the big washer that goes under the spring. I have a couple of extras.
LockDoc
Leon
Old 01-09-2014, 03:39 PM   #11
sboris
sboris's Avatar
Originally Posted by LockDoc View Post
Shawn,
LockDoc
Thankyou Leon, pics are king. I will look tonite for the washer and let you know.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 01-09-2014, 07:08 PM   #12
athleo
athleo's Avatar
This is the washer that you are missing!......dwt.
1990 K3500
Old 01-09-2014, 07:26 PM   #13
sboris
sboris's Avatar
Good pic! It always helps when a guy keeps all the parts I should have it somewhere..
Thankyou for all your help.
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 01-13-2014, 08:48 AM   #14
sboris
sboris's Avatar
Update, didn't find the stock washer, but had one plenty thick, and fit the shaft perfectly. The diameter is a little smaller, but don't see that being an issue..
Thanks to everyone for the help and chiming in. Finished product
Shawn
68 chevy K/20
05 chevy 3/4 4x4
71 short step-sold
My build.
Old 01-13-2014, 09:13 AM   #15
Ol Blue K20
Proprietor of Dale's Corner
Ol Blue K20's Avatar
Congrats...nice to see it together
Dale
XNGH ECV Sam Brannan 1004
R.I.P. 67ChevyRedneck
R.I.P. Grumpy Old Man
R.I.P. FleetsidePaul
Old 01-13-2014, 09:38 AM   #16
LockDoc
LockDoc's Avatar
Looks Good. Glad you got it sorted out.
LockDoc
Leon
Thread Tools
Display Modes
