Old 01-11-2014, 05:37 PM   #1
bob8619
New guy
Hey guys, just picked up a 72 C10 with the 350 a few days ago and I've been looking everything over. I searched but did not find any help so I decided to make this my first post.
I noticed last night that with the engine running I am getting 11.8v at the battery. I had the alternator tested at the the auto parts store and they said it passed everything so I figured ok the regulator is bad so I bought one. Installed the regulator and I'm still getting 11.8v while running. 12v when the engine is off.
This may be the wrong way of testing the alternator but I put my volt meter to it, one to where the nut connects the red wire and another to each of the other contacts, between the nut and one of the contacts I get 11.8 volts. Engine running by the way, different RPMS and it stays 11.8
Is this alternator bad or did I test it wrong?
Thanks guys
Bob
bob8619 is offline   Reply With Quote
Old 01-11-2014, 05:45 PM   #2
bob8619
Re: New guy
A bit of added info, the battery has not died on me since I've owned it and I've had the lights on and radio on A LOT. Not to mention I have had it running a lot as well.
Old 01-11-2014, 05:47 PM   #3
70LonghornCST
Moderator
70LonghornCST's Avatar
Re: New guy
Hi Bob, and welcome!
At first in reading your post, I was thinking it may be experiencing a draw due to erratic idling. My Plymouth does just that. However, you state that with the "Engine running by the way, [you get] different RPMS and it stays 11.8," makes me think it may be the alternator or voltage regulator. If the RPMs bounced with the different it COULD be a draw from a poorly adjusted carb or something else. Electrical is not my area of expertise. I know that some of our board gurus will chime in shortly.
Again, welcome and glad to have you here!
-Richard
2018 Chevy Crew Cab
2006 Impala SS
1965 Plymouth Sport Fury
1970 Chevy Longhorn
  • Bucket Seats
  • Shoulder Belts
  • Front Tow Hooks
  • Factory Air
  • Factory Speedwarning, Tach & Vaccum
  • Factory Tilt
  • CST Package
  • AM/FM Radio
  • Bumper Guards
Richard
70 Longhorn CST Build
Adding an AM/FM Decal
70LonghornCST is offline   Reply With Quote
Old 01-11-2014, 05:50 PM   #4
bob8619
Re: New guy
Thanks for the welcome!
And just to be clear, when I said different RPMs I meant when I change the RPMs its the same voltage. Not that the rpms are bouncing around on their own.
Old 01-11-2014, 09:50 PM   #5
bob8619
Re: New guy
I took it to another store and they also tested it and said it was good. I noticed though that one of the connector tabs was loose and would slide upward. I figured that probably rattles when the engine is on and doesnt make good contact. I decided to just buy a new alternator and now I get 13.4 volts at idle.
Old 01-11-2014, 09:53 PM   #6
Mathew21
Mathew21's Avatar
Re: New guy
Welcome, Sounds like you fixed your problem.
Mathew21 is offline   Reply With Quote
Old 01-11-2014, 09:54 PM   #7
bob8619
Re: New guy
Thanks Mathew21. I have more problems but I dont know if I should start a new thread or add here. hmmmm
Old 01-11-2014, 11:33 PM   #8
spatz
Re: New guy
Welcome to the site. Just start a new post and with the caption of what you need would be the easiest way to get the right answers.
spatz is offline   Reply With Quote
Old 01-15-2014, 12:34 AM   #9
bob8619
Re: New guy
Hi guys. Been chasing other issues and tested my battery tonight while running. 12.4 at idle and no rise in voltage til probably 2000rpm. Any other ideas? Im at a loss
Old 01-15-2014, 02:34 AM   #10
70cst
70cst's Avatar
Re: New guy
Hey bob8619
to the forums and from Ohio ...
A husband can be right...or...A husband can be happy.
67-72 Chevy and GMC Trucks...The Classic Truck for the Classic Folk.
1970 CST Two tone green, 402BB, 400 Automatic, Tach, Buckets, AC, AM-FM, Tilt, GM CB, GM 8 Tract, LWB, etc
JOHN 17:3...The better side of "LIFE"
Remember: Everyday is a good day...Some are just gooder!
70cst is offline   Reply With Quote
Old 01-15-2014, 02:51 PM   #11
Racer2172
Re: New guy
Some alternators dont start charging till over certain RPMS. Could be the reason.
65 C-10 Times gone by(Sons truck)http://67-72chevytrucks.com/vboard/s...92#post6164692
70 C-30 Tow truck AKA Highlighter
02 Silverado 2500 HD CUCVII Tow Rig/DD
1968 C10 Project Quarantine http://67-72chevytrucks.com/vboard/s...d.php?t=804800
1980 Buick Regal Dirt Stock car
Racer2172 is offline   Reply With Quote
Old 01-15-2014, 02:57 PM   #12
bob8619
Re: New guy
I guess it was a problem with one of my grounding wires. Ran new grounds and now I'm at 14.4 at idle.
Old 01-15-2014, 04:52 PM   #13
Racer2172
Re: New guy
Good grounds are key in electrical flow. I personally ground block to frame and block to cab as well as battery negative post directly to the engine.
Old 01-15-2014, 05:09 PM   #14
bob8619
Re: New guy
It still acts kinda funny. When I first start it and even while its choked and running about 1500rpm its saying 12.x volts. When it comes down to regular idle and I rev the engine then it'll go to 14.xx volts. Is this one of those that have to be excited before putting out higher voltage?
Thread Tools
Display Modes
