Old 01-12-2014, 07:03 PM   #1
OKGMC4
OKGMC4's Avatar
rear axle code ID
I've searched all over and can't find any way to decode the numbers. I've seen car axle ID charts, and RPO number ID charts, but not truck axle ID references. I have two axles and would like to know what they are. One is an inline six automatic 69 chevy coil rear and the code is HA1230A. The other is unknown. It came in my 56 GMC when I bought it. It's been in the backyard since I did a C4 rear end swap. It has the panhard hole on top so I know it's a C10 rear and it appears to be a posi. Code on that one is HA0518W. To get the posi I'm thinking I'll cut the coil brackets and weld them onto the leaf rear since I know nothing about setting up rear diff carriers. Thanks for any info...Mike
56 GMC BUILD THREAD:
http://67-72chevytrucks.com/vboard/s...d.php?t=368649
69 long bed Chevy turned 67 gmc jimmy roadster:
https://67-72chevytrucks.com/vboard/...d.php?t=851167
OKGMC4 is offline   Reply With Quote
Old 01-12-2014, 07:20 PM   #2
LockDoc
The Older Generation
LockDoc's Avatar
Re: rear axle code ID
Try these...
http://67-72chevytrucks.com/vboard/s...d.php?t=578793
The numbers in the Red Chart will be found stamped into the ring gear.
LockDoc
Leon
Old 01-12-2014, 07:36 PM   #3
OKGMC4
OKGMC4's Avatar
Thanks for the link! I also found this site just now...
http://www.gmcpauls.com/67-72_chevy.htm
It would seem that my posi axle is not supposed to be, as both are HA axles which would indicate 3.73 non posi. I wonder if there is any way to ID the year? Looks like the HA code was used for several years on C10 trucks. I'd have to pull the axles to find out but as I understand some early 12 bolts only had 17 spline axles instead of the regular 30. All the aftermarket 5 lug conversions seem to be for 30 spline.
Thread Tools
Display Modes
