Old 01-18-2014, 06:42 AM   #1
singledoutc10
68 c10 with 350sbc swapped, clutch?
My grandpa gave me his 68 c10 about 2 yrs ago. When he gave me the truck the clutch was slipping. Recently my daily driver took a crap on me so the c10 has became my daily driver. About 35 yrs ago my dad swapped the inline 6 for 350sbc. It has a 3 on the tree manuel. What clutch do I order? And if the flywheel is bad which flywheel do I order? I'm asking here bc my dad did the swap but he pasted away about 6 yrs ago
singledoutc10 is offline   Reply With Quote
Old 01-18-2014, 07:03 AM   #2
71chevyc10hvycvy
Re: 68 c10 with 350sbc swapped, clutch?
Was the truck originally manual
71chevyc10hvycvy is offline   Reply With Quote
Old 01-18-2014, 07:53 AM   #3
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
You'll have to remove it and measure the clutch size. The flywheels interchange between most six cylinder engines and 350s. The V8 used a larger clutch and flywheel than sixes did. So, without measuring, you don't know if he used the original six cylinder flywheel and clutch on the 350 or whether the 350 had a flywheel and clutch that he used.
Old 01-18-2014, 10:37 AM   #4
singledoutc10
So if I wanted to buy a new clutch and flywheel I could go to advance auto and buy both for a c10 that had a 350? And yes it was factory 3 on the tree.
Old 01-18-2014, 10:55 AM   #5
Lattimer
Lattimer's Avatar
Correct. As long as the clutch and flywheel are the same size, you will be ok. You need a clutch for a 10 spline trans input, and a matching flywheel. I'd go with an 11" clutch and a flywheel drilled for that.
IF you change flywheel sizes (# of teeth) you may have to replace the starter as well.
If you are not going high performance, something like this will work fine:
http://www.summitracing.com/parts/zz...make/chevrolet
http://www.summitracing.com/parts/ra...make/chevrolet
Shawn
1970 Chevy C-10 SWB, 350, TKO 600 5 speed
My build http://67-72chevytrucks.com/vboard/s...d.php?t=559881
Lattimer is offline   Reply With Quote
Old 01-18-2014, 11:00 AM   #6
singledoutc10
Thanks, I'm not going for performance, just make it reliable.
Thread Tools
Display Modes
