Old 01-19-2014, 05:49 PM   #1
Roscoep
Roscoep's Avatar
How To Remove Clutch Petel - Pic.
Converting to auto. transmission and need to remove clutch petal, where do I start? Took photos of both sides.
Robert
71 Chevy SWB
Roscoep is offline   Reply With Quote
Old 01-19-2014, 06:08 PM   #2
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
Re: How To Remove Clutch Petel - Pic.
Here is a picture I made up 10 years ago for someone who had the same question.
Step 1 remove pinch bolt
Step 2 remove arm from shaft
Step 3 slide pedal towards the left, out of pedal box
Old 01-19-2014, 06:34 PM   #3
Roscoep
Roscoep's Avatar
Thanks TX Firefighter. Now what do I do after I get it apart?
Robert
71 Chevy SWB
Old 01-19-2014, 06:37 PM   #4
Tx Firefighter
Is that a trick question ?
You asked how to remove the pedal. Follow those three steps and you'll have the pedal in your hands.
Old 01-19-2014, 07:01 PM   #5
Roscoep
Roscoep's Avatar
Sorry, I wasn't trying to cute. I don't need the clutch pedal anymore. Once I get it apart, how to I get the pedal off the rod and just have the break pedal?
Robert
71 Chevy SWB
Old 01-19-2014, 07:06 PM   #6
Tx Firefighter
The clutch and brake pedals are not connected. Once you remove the clutch pedal the brake pedal will be still fully installed like it's always been. The clutch pedal pivot shaft actually passes through the hollow center of the brake pivot.
Old 01-19-2014, 09:14 PM   #7
Roscoep
Roscoep's Avatar
Now I see, thanks a lot TX Firefighter, I have followed your post for sometime and you have helped a lot
Robert
71 Chevy SWB
Old 01-19-2014, 09:25 PM   #8
Tx Firefighter
You're welcome Robert. Always glad to help when I can. Best of luck.
Thread Tools
Display Modes
