01-25-2014, 12:26 PM | #1 |
cs130 alt in a 72 c10
ok..guys I have a 72 c10 with all the brackets and pullys from a 94 chevy..and a new American autowire harness but cant get my alternater to work...everything is new alt,batt belts...how do these wires hook up...thanks
01-25-2014, 06:10 PM | #2 |
Msgt USAF Ret
Re: cs130 alt in a 72 c10
Is you new AA harness completely stock or has it been upgraded to the CS alternator.
Look at the harness near the large red wire for the alternator and check the plug that goes into the alternator. This is a good thread for the conversion but it starts out for the SI style alternator and goes on to the CS style. Check the link I posted for the CS conversion and also read the whole thread. if you don't follow any of it just post back and I'll help you out. ........ http://67-72chevytrucks.com/vboard/s...d.php?t=320787
VetteVet metallic green 67 stepside 74 corvette convertible 1965 Harley sportster 1995 Harley wide glide Growing old is hell, but it beats the alternative. |
01-25-2014, 08:34 PM | #3 |
I read the whole thread but still don't get it...and I have the American autowire 510089 classic updated kit...thanks for your help
01-25-2014, 09:08 PM | #4 |
Hollister Road Co.
You have a battery stud that comes out the back or the alt. it goes to the battery or starter stud with a fusible link in it. You have a red wire coming out of the alt plug. connect it to the battery wire about 18" to 24" back into the wire. You have a brown wire coming from the ignition connect it to the "L" wire on the plug.
01-25-2014, 09:52 PM | #5 | |
Msgt USAF Ret
OK answer these questions for me and we'll get started. 1. Do you have the external voltage regulator with the four wire plug that's mounted on the left radiator support? 2. Which alternator do you have. Is it the 72 or the one from the 94. 3. Do you have the idiot light dash or the charging gauge dash?
01-25-2014, 10:31 PM | #6 | |
Hollister Road Co.
01-25-2014, 11:17 PM | #7 | |
Msgt USAF Ret
Do you know if the kit has HEI wiring and the headlight relay mod? His subject line says CS 130 so I guess that's it.
01-25-2014, 11:22 PM | #8 |
Msgt USAF Ret
Dave, you got any ideas on this one.
......http://67-72chevytrucks.com/vboard/s...d.php?t=613632
01-25-2014, 11:56 PM | #9 |
ok....1 no external regulater 2, 94 alternater ,3,,charging gauge dash...thanks vettvet
01-26-2014, 12:30 AM | #10 |
Msgt USAF Ret
Ok that's why I asked about the wiring harness and the wires for the alternator.
If you want your battery gauge to work in the dash then wire it just like this picture. Your harness may not be setup like this diagram. in fact it may not even have the two small 18 gauge black wires and the fuses that the gauge requires. If you can find the 16 gauge brown wire that comes from the bulkhead connector to the alternator, it should have the resistor in it and it should be in the alternator plug connected to the L terminal on the alternator. The other wire is the red 12 gauge wire for the S terminal and the large wire is probably a 10 gauge red wire that connects to the back of the alternator.
01-26-2014, 05:36 PM | #11 |
vettevet took youre information and went to work...you solved all my problems ...thank you very much....awesome people on this board !!!!
01-26-2014, 05:58 PM | #12 |
Msgt USAF Ret
That's great!!!! now if the Bronco's can only win the super bowl.
Thread Tools | |
Display Modes | |
