How to replace frame rivits
Awhile back someone posted this same question, and a reply was you can still buy the rivits. Since search is down I cannot find the post. If you can still get the rivits- where can you get them-How would you smash them.
Formerly yellow72custom
Just replace the rivits with a grade 8 bolt and lock washers....they will work just as well as a rivit, but allow you to take it apart much easier.
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride. '70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck. '97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg |
14.1 @ 96MPH
I second the grade 8 hardware - much easier to deal with.
Project1970 - LS1 Swap Complete! ![]() |
its all about the +6 inches
Actually, i would go with a grade 5.
The grade 5 is actually stronger when it comes to side loads, the grade 8 is better for clamping ability. |
Constantly on this board everyone wants back to original condition which would mean replacing the rivets..Sounds like you would need what they call at least a 9X air riveter, the proper size rivets, and of course rivet head for the gun and a good heavy bucking bar. original rivet replacement if you needed to buy the equipment would cost a person about $300..(used)
Although other sources for rivets probally exist. One way would be to get diameter of the whole you want to fill and order thru a rivet supplier from someplace like US STEEL..or a company that deals in Aviation type fastners....So probally grade 8 hardware would be the cheaper route..
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
![]() Join Date: Dec 1999
If you look in one of the factory repair manuals I think it says something about replacing them with a nut/bolt that you tighten then heat to cherry and tighten again.
Kind of forget the details but I'm pretty sure it is in the chassis manual. ![]()
68C10 1968 C10 SWB No Options but 40K original miles 1967 K20 LWB 283 4-speed South Plainfield, NJ |
Thanks for the input guys. Sammy your info. is what I'm looking for. Who ever made the post before said they replaced all thier rivits with new ones and we were wanting to know how they smashed them.
Buy Sale or Trade 71 3/4 4x4 72 1/2 ton cheyenne 4x4 |
Fabricate till you "puke"
a while back, one of the guys talked about using lug studs & nylock nuts to replace the rivets(Dually ,i think). At any rate, that would give you that stock look on the outside of the frame, & should be plenty strong(much cheaper also). I have used 7/16 x 1" grade 8 bolts, & pinch lock nuts for any pcs removed /replaced on my longhorn. I would stay away from lock washers, pinch lock, or nylock nuts will keep things in place better. also a good snug fit on the bolt hole is best. Good luck,crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
Calibration Engineer
i used 7/16 x 1" grade 8 bolts with pinch lock nuts and washers on each side
Thread Tools | |
Display Modes | |
