Old 07-21-2003, 12:36 AM   #1
Chevy_68
Chevy_68's Avatar
cab alignment
how would you know if the cab is on the frame right it look strait to me but cant get fenders on right . ill post some pics
Chevy_68 is offline   Reply With Quote
Old 07-21-2003, 12:39 AM   #2
FRENCHBLUE72
PROJECT 7DEUCE
FRENCHBLUE72's Avatar
Just did this today!!!!! Cab is gotta be easier than a blazer tub. Take measurement's from the body mount's to the body or some place you know is straight( like seat belt hole's )and make sure that they are the same from side to side...
GO BIG GREEN GO DUCKS
MEMBER #6377
Project "7DEUCE"
Old 07-21-2003, 02:11 PM   #3
Blue4x4
Blue4x4's Avatar
cab alignment
Measure off the frame. I put on aftermarket fenders and the gap between the doors and front fenders was excessivly large. I ended up installing extra shims in the front of the cab to close the gap. good luck.
Blue4x4 is offline   Reply With Quote
Old 07-22-2003, 05:36 AM   #4
tmad
Had the same trouble! All you can do is measure what you can. You may still have to add shims in a few spots.
tmad is offline   Reply With Quote
Thread Tools
Display Modes
