07-21-2003, 08:59 AM | #1 |
T221 to NP205 swap
Just picked up another 67 3/4 ton and looking to swap the T221 transfer for the NP205. (as well as a 14bolt) Can anyone tell me exactly whats involved and the parts needed? I wish the search was working because I know this has been covered MANY times.
I assume the crossmember will be the NP205 version from a 69-72? What about shifter location? Driveshaft longer from the increased angle? Speedo hookup? SM420 issues? Thanks in advance! |
07-21-2003, 12:19 PM | #2 |
Recovering 67-72 Addict
The crossmember is the same for the 221 and the 205 so you don't need to change that. The hole for the shifter will be in a different location. I just bought a new hump with the appropriate hole in it. I used my same speedo cable as well. As far as the driveshaft is concerned, I am not sure in your case. I moved everything forward to accomadate the big block so I had to redo the driveline. Make sure that you get the adapter that goes with the 205 because your existing 221 adapter is different.
68 Short Fleet 4x4; 427; BTO Level 3 700R4; NP205; Dana 60 front and rear; 4" lift with 35's; Disc brakes; AGR variable ratio steering; factory bucket seats; factory tach and tilt. "Friends call me cruzer cuz I like fast cars and fast women" |
07-21-2003, 12:28 PM | #3 |
Thanks Breeh ... which adapter for the SM420 fits the NP205? Is it the same as the SM465?
07-21-2003, 12:53 PM | #4 |
There is no adapter to marry an NP205 to a SM420. Your best bet would be to find a 465/205 combo with the adapter to swap in.
Tim |
07-22-2003, 01:48 AM | #5 |
unless there is something wrong with the 221, I would just leave it in there. if its broken, a 205 is probably cheaper than the parts.
1969 GMC K2500 1996 Honda Accord 2007 Kawasaki KLR 650 |
Thread Tools | |
Display Modes | |
